Scott06
replied to the thread
No dipstick on 1989 era 3.0L?
Rotella T4 15w 40, I also used to run super tech 20w50 no issue in my 3.0. Don’t over think it too much.
Apr 11, 2026
P
pae0332
why is there oil in my bellows but pressure test holds 15psi overnight
agreed, drop pressure to different levels
Apr 11, 2026
LaqueRatt
Boat Cover Repair?
Some good ideas for sure. Tear-aid looks interesting. Anybody actually try this stuff? Tempted to try Flex Tape, but everything I use...
Apr 11, 2026
J
JasonB
posted the thread
Stripped drain plug
in
Boat Restoration, Building, and Hull Repair
Just picked up an old Richline 15 Aluminum boat that has a ~1” dia screw in drain plug. Unfortunately, the threads are mostly stripped...
Apr 11, 2026
J
JasonB
posted the thread
Plug wires for ‘71 Merc 20hp
in
Mercury & Mariner Outboards
Picked up an old ‘71 20hp to play with and found a broken plug wire. I patched it together enough to verify it will run, but will...
Apr 11, 2026
M
MikeSchinlaub
Stuck floor board over gas tank on Alumacraft
Any chance you have access to a chain hoist? You could try putting a bar or something in the vent hole and pulling with the hoist.
Apr 11, 2026
R
robertjp
These are/should be designed to remove because gas tanks and senders need to be inspected/replaced from time to time. All screws are...
Apr 11, 2026
flashback
Pushing Run-Flat tires to the limit
Generally if I'm in the left lane I'm gonna be passing someone at some point. Dumb law!
Apr 11, 2026
J
jumbofordman
posted the thread
454 Water pump hoses
in
Mercury MerCruiser Sterndrives & Engines
So I had to replace one of my exhaust manifold gaskets, and while I was looking around at things that might need replacing I realized my...
Apr 11, 2026
A
airshot
Many laws are not enforced by police, and that is a big cause of road rage ! Another big issue is keeping right except to pass. A law...
Apr 11, 2026
dingbat
reacted to
WIMUSKY's post
in the thread
Just thought I'd share a nice photo.
with
Like
Me with a pompano. Ignore me...😳
Apr 11, 2026
dingbat
reacted to
Pmt133's post
in the thread
with
Like
I expect it no where. :ROFLMAO:
Apr 11, 2026
R
rogerlamb123
Which kicker mount to install?
Are you saying to add a plate between the mount and the swim platform? The concern I have is that there is no way to get access to the...
Apr 11, 2026
FLATHEAD
reacted to
WIMUSKY's post
in the thread
with
Like
Apr 11, 2026
FLATHEAD
reacted to
WIMUSKY's post
in the thread
with
Like
Fred!
Apr 11, 2026
