nola mike
reacted to
Scott Danforth's post
in the thread
projects other than boats
with
Like
in respect for the Artemis II project. All seriousness aside. a great team of engineers that once worked for me worked on the bird.
Apr 11, 2026
nola mike
replied to the thread
Pushing Run-Flat tires to the limit
I rented a Pacifica a few years ago, really liked it. More fun to drive than a huge suv, better layout, great mileage and surprisingly...
Apr 11, 2026
nola mike
why is there oil in my bellows but pressure test holds 15psi overnight
I mean, only place for it to come from is the input shaft seal, right?
Apr 11, 2026
S
saltchuckmatt
'84 90hp crossflow. J90 MLCRD. Reed valve filler blocks. part # 0322684. When?
What was your motor doing/not doing to make you pull those?
Apr 11, 2026
Kola16
posted the thread
Does This Sound Right? Bravo Install
in
Mercury MerCruiser Sterndrives & Engines
I replaced my old MC-1 drive with a used Bravo drive assembly. I installed a new gimbal bearing, U-joints, and drive oil in the new...
Apr 11, 2026
M
Mc Tool
Stripped drain plug
How about something like this 😀
Apr 11, 2026
Scott06
No dipstick on 1989 era 3.0L?
Rotella T4 15w 40, I also used to run super tech 20w50 no issue in my 3.0. Don’t over think it too much.
Apr 11, 2026
P
pae0332
agreed, drop pressure to different levels
Apr 11, 2026
LaqueRatt
Boat Cover Repair?
Some good ideas for sure. Tear-aid looks interesting. Anybody actually try this stuff? Tempted to try Flex Tape, but everything I use...
Apr 11, 2026
J
JasonB
posted the thread
Stripped drain plug
in
Boat Restoration, Building, and Hull Repair
Just picked up an old Richline 15 Aluminum boat that has a ~1” dia screw in drain plug. Unfortunately, the threads are mostly stripped...
Apr 11, 2026
J
JasonB
posted the thread
Plug wires for ‘71 Merc 20hp
in
Mercury & Mariner Outboards
Picked up an old ‘71 20hp to play with and found a broken plug wire. I patched it together enough to verify it will run, but will...
Apr 11, 2026
M
MikeSchinlaub
Stuck floor board over gas tank on Alumacraft
Any chance you have access to a chain hoist? You could try putting a bar or something in the vent hole and pulling with the hoist.
Apr 11, 2026
R
robertjp
These are/should be designed to remove because gas tanks and senders need to be inspected/replaced from time to time. All screws are...
Apr 11, 2026
flashback
Generally if I'm in the left lane I'm gonna be passing someone at some point. Dumb law!
Apr 11, 2026
J
jumbofordman
posted the thread
454 Water pump hoses
in
So I had to replace one of my exhaust manifold gaskets, and while I was looking around at things that might need replacing I realized my...
Apr 11, 2026
