Horigan
replied to the thread
Noise after replacing impeller and fuel/water separator
That's how I do it also, but if you inadvertently install the vanes in the wrong direction, they bend in the right direction as each...
Apr 12, 2026
matt167
No dipstick on 1989 era 3.0L?
I grabbed 15W40 Rotella T4. My local Walmart got rid of all the marine section in automative. Sporting goods section has the Penzoil...
Apr 12, 2026
nola mike
posted the thread
Ideas for planters/raised beds?
in
Non-Boating Technical Topics
My raised garden beds have needed to be replaced for at least 5 years. I never seem to get around to it in time. This year is no...
Apr 12, 2026
R
Which kicker mount to install?
I doubt that anyone needs to invest $10,000 so they can go slow.
Apr 12, 2026
D
DeepCMark58A
2026 NFL/CFB News and Nonsense
Guy is washed and will play his last season on a 500 team.
Apr 12, 2026
rolmops
If there really is no access, which I doubt, you might want to consider an alternative option like getting a Yamaha main engine that has...
Apr 12, 2026
C
why is there oil in my bellows but pressure test holds 15psi overnight
Look at the sealing surface of the yoke. If there is a groove, the seal will leak. Replacement will be in order.
Apr 12, 2026
P
Pmt133
I've seen cheap grease look like lube in the bellows too. Flung and burned down from the gimbal and u-joints. I agree with the...
Apr 12, 2026
P
Pmt133
Pushing Run-Flat tires to the limit
The old maintain flow of traffic. During rush hour I've been passed doing very illegal speeds. Like lose you license immediately speeds...
Apr 12, 2026
C
Stripped drain plug
Garboard drain fittings are avail. A couple of thru bolts and some silicone could install it.
Apr 12, 2026
nola mike
reacted to
alldodge's post
in the thread
Sierra TC-W3 2 Stroke Synthetic Blend Marine Engine Oil
with
Like
West Marine has a sale on for folks that use 2 cycle Was $55 a gallon, now it's $13.64
Apr 12, 2026
J
JasonB
Stripped drain plug
That’s my immediate plan until I maybe work out something for the original.
Apr 12, 2026
dingbat
Maryland law goes one step beyond….you must travel in the right lanes if traveling 10 mph below the flow of traffic and you can’t...
Apr 12, 2026
reacted to
nola mike's post
in the thread
with
Like
I mean, only place for it to come from is the input shaft seal, right?
Apr 12, 2026
P
Pmt133
reacted to
redneck joe's post
in the thread
I/O (Sterndrive) Conversion to Outboards
with
Like
Remember to tell the wife tools are not a charge to the budget. I have an old thread here somewhere that confirms that.
Apr 12, 2026
