D
DeepCMark58A
replied to the thread
Been a little cold.
The snowman that was made on Easter fell over, I believe we are snow free, the lake opened up yesterday. It smells like spring outside.
Apr 12, 2026
230 Mike
posted the thread
Can't change password
in
iboats Forum and Website Issues
I can log in, but I need to change my password. When I go through that process, I get to the point where "A password reset request has...
Apr 12, 2026
C
Plug wires for ‘71 Merc 20hp
I looked up the plug wires from a '75 Merc 20...
Apr 12, 2026
Lou C
Pushing Run-Flat tires to the limit
With 10 speed auto transmissions that 55 mph speed limit is more of a money grab than ever. Remember when that crap started in 1974? We...
Apr 12, 2026
Horigan
Noise after replacing impeller and fuel/water separator
Great! Maybe cycle the steering wheel back and forth with the engine running to ensure any air in the steering system is purged. I'd...
Apr 12, 2026
C
No dipstick on 1989 era 3.0L?
So the old Merc manual says no multi vis oil, and you plan to use 15W40 multivis oil? It may even protect your motor, who knows...
Apr 12, 2026
Horigan
That's how I do it also, but if you inadvertently install the vanes in the wrong direction, they bend in the right direction as each...
Apr 12, 2026
matt167
I grabbed 15W40 Rotella T4. My local Walmart got rid of all the marine section in automative. Sporting goods section has the Penzoil...
Apr 12, 2026
nola mike
posted the thread
Ideas for planters/raised beds?
in
Non-Boating Technical Topics
My raised garden beds have needed to be replaced for at least 5 years. I never seem to get around to it in time. This year is no...
Apr 12, 2026
R
Which kicker mount to install?
I doubt that anyone needs to invest $10,000 so they can go slow.
Apr 12, 2026
D
DeepCMark58A
2026 NFL/CFB News and Nonsense
Guy is washed and will play his last season on a 500 team.
Apr 12, 2026
rolmops
If there really is no access, which I doubt, you might want to consider an alternative option like getting a Yamaha main engine that has...
Apr 12, 2026
C
why is there oil in my bellows but pressure test holds 15psi overnight
Look at the sealing surface of the yoke. If there is a groove, the seal will leak. Replacement will be in order.
Apr 12, 2026
P
Pmt133
I've seen cheap grease look like lube in the bellows too. Flung and burned down from the gimbal and u-joints. I agree with the...
Apr 12, 2026
P
Pmt133
The old maintain flow of traffic. During rush hour I've been passed doing very illegal speeds. Like lose you license immediately speeds...
Apr 12, 2026
