Kola16
reacted to
Fun Times's post
in the thread
Does This Sound Right? Bravo Install
with
Like
No, doesn't sound right... maybe try pulling the drive off and see if the noise goes away/changes....But be sure to add water to the...
Apr 12, 2026
nola mike
posted the thread
Throttle cable replacement...
in
Mercury MerCruiser Sterndrives & Engines
Have had a sticking throttle cable that got annoyingly bad last season. Had a spare box/cable from the old donor boat. I pulled the...
Apr 12, 2026
S
Shawnspeed
replied to the thread
StarCraft 181 SS conversion
So , it’s been a minute… and I’ve abandoned the Tube Transom, and went back to a marine grade plywood transom, the added cost of the...
Apr 12, 2026
T
tphoyt
reacted to
tpenfield's post
in the thread
I/O (Sterndrive) Conversion to Outboards
with
Like
I cleaned-up some of the wiring in the (former) engine bay in preparation for some grinding and glassing. . . I put a few 1/2" spacers...
Apr 12, 2026
nola mike
Almost there
So went back to the boat after a couple of weeks. Fluid level normal. There has been some oil in the bilge since I pulled the engine...
Apr 12, 2026
P
Pmt133
reacted to
tpenfield's post
in the thread
with
Like
Apr 12, 2026
tpenfield
Apr 12, 2026
redneck joe
Ideas for planters/raised beds?
Wood will be gone to sh.t is a couple years. Fiberglass tubs are your answer. Got a dremel and a kid/grandkids? Make the base an...
Apr 12, 2026
P
Pmt133
reacted to
gmach's post
in the thread
95 Sea Ray 230 Sundancer stringer repair
with
Like
Well, I've decided to use thickened epoxy to bed the transom. The bad part is, I will have to baby sit the job with a rag and acetone to...
Apr 12, 2026
flashback
reacted to
airshot's post
in the thread
Which kicker mount to install?
with
Like
While not easy, some how you need to access the underside of that flat surface as that would be the easiest area to attach a mount. One...
Apr 12, 2026
redneck joe
2026 NFL/CFB News and Nonsense
A team leader is not washed, sports or business and I'll put money on the 500 mark.
Apr 12, 2026
redneck joe
Is the kicker for trolling or ba k up poswer?
Apr 12, 2026
redneck joe
reacted to
FLATHEAD's post
in the thread
old pictures
with
Like
Cousin sent me this. I’m guessing 1965 or 1966. I’m the kid second from left. The others are my sisters , cousins and Aunt.
Apr 12, 2026
T
tphoyt
reacted to
DeepCMark58A's post
in the thread
Been a little cold.
with
Like
The snowman that was made on Easter fell over, I believe we are snow free, the lake opened up yesterday. It smells like spring outside.
Apr 12, 2026
reacted to
alldodge's post
in the thread
Metal O-Ring appeared on alignment tool
with
Like
That's the inner spine on a lip type seal. Probably from the grease seal behind the gimbal bearing Edit Bondo was quicker
Apr 12, 2026
