tpenfield
replied to the thread
I/O (Sterndrive) Conversion to Outboards
The words for the day are 'pressure washer' . . . :ROFLMAO: that will do the trick. I think I there may be a new pressure washer in my...
Apr 13, 2026
P
PrCunningham
posted the thread
Alpha One Gen II Lower Unit - Drive Shaft Binds When Tightening Retainer
in
Mercury MerCruiser Sterndrives & Engines
I have a MerCruiser Alpha One Gen II sterndrive. I pulled the lower unit apart to diagnose what I thought was a lower unit problem —...
Apr 13, 2026
Volvo aq270T gimbal bearing
yes, pull the drive off. then bend the corners of the tabs, remove the bolts. then grease up the threads of 3 of the bolts and put...
Apr 13, 2026
yes, the rubber donuts (too thick to be an o-ring)
Apr 13, 2026
C
ChadAustin
This correct ? There is a rubber gasket behind that plate
Apr 13, 2026
C
ChadAustin
Beautiful I was Just thinking I can tip but I doubt i be able to put it back the same way lol I found a manual but it’s gonna take 10-14...
Apr 13, 2026
FLATHEAD
4 all y'all still shovelin snow
Hitting 90* here on Wednesday. Had the wood stove going two days ago in the morning, most likely last fire till mid to late fall.
Apr 13, 2026
Lou C
Does This Sound Right? Bravo Install
Agree with those above, does not sound right, run it with the drive off. Does it change when you tilt up or down, or steer left or...
Apr 13, 2026
Lou C
The older I get the less tolerance I have for the 4 months of lousy weather we get in southern NYS. In the winter it's either moderately...
Apr 13, 2026
yes however once you pull the clamp and the donut, you can tip the motor up / sideways a bit. otherwise you need 4" of clear space...
Apr 13, 2026
you have to call your local VP dealer. since the website only goes back to 2000 and the AQ series were only around until 1996
Apr 13, 2026
C
New Jersey usually gets two weeks of extreme heat and extreme cold (by NJ standards) each year. Here at the shore that translates to...
Apr 13, 2026
C
ChadAustin
That part circled in red it has to come out with the engine? from the engine side of the boat? cause I have about 1/2” of clearance...
Apr 13, 2026
C
ChadAustin
Apr 13, 2026
C
ChadAustin
I agree with that 💯 % but I can’t seem to find one I ordered a maintenance that dies cover some of it but doesn’t show exactly how to...
Apr 13, 2026
