redneck joe
replied to the thread
Ideas for planters/raised beds?
Food grade ones. Not all are chemicals
Apr 13, 2026
redneck joe
I've done that
Apr 13, 2026
I/O (Sterndrive) Conversion to Outboards
5015 debonder from worst marine works to loosen the bond of 5200
Apr 13, 2026
T
tphoyt
My daughter once made a hydroponic garden for a school project that used the water from a fish tank which in turn fed the plants. It was...
Apr 13, 2026
M
MikeSchinlaub
I've read that it needs very precise control of the nutrients in the water.
Apr 13, 2026
Captain Caveman
reacted to
Mc Tool's post
in the thread
with
Like
Why not go hydroponic ? There is a lot less structure and space needed .
Apr 13, 2026
tpenfield
The words for the day are 'pressure washer' . . . :ROFLMAO: that will do the trick. I think I there may be a new pressure washer in my...
Apr 13, 2026
P
PrCunningham
posted the thread
Alpha One Gen II Lower Unit - Drive Shaft Binds When Tightening Retainer
in
Mercury MerCruiser Sterndrives & Engines
I have a MerCruiser Alpha One Gen II sterndrive. I pulled the lower unit apart to diagnose what I thought was a lower unit problem —...
Apr 13, 2026
Volvo aq270T gimbal bearing
yes, pull the drive off. then bend the corners of the tabs, remove the bolts. then grease up the threads of 3 of the bolts and put...
Apr 13, 2026
yes, the rubber donuts (too thick to be an o-ring)
Apr 13, 2026
C
ChadAustin
This correct ? There is a rubber gasket behind that plate
Apr 13, 2026
C
ChadAustin
Beautiful I was Just thinking I can tip but I doubt i be able to put it back the same way lol I found a manual but it’s gonna take 10-14...
Apr 13, 2026
FLATHEAD
4 all y'all still shovelin snow
Hitting 90* here on Wednesday. Had the wood stove going two days ago in the morning, most likely last fire till mid to late fall.
Apr 13, 2026
Lou C
Does This Sound Right? Bravo Install
Agree with those above, does not sound right, run it with the drive off. Does it change when you tilt up or down, or steer left or...
Apr 13, 2026
Lou C
The older I get the less tolerance I have for the 4 months of lousy weather we get in southern NYS. In the winter it's either moderately...
Apr 13, 2026
