N
Nordin
replied to the thread
1987 Force 50hp head warpage.
Yes like racerone says. Resurface it at a piece of glass and water sanding paper. sand it and do it in a 8 pattern way. Check it with a...
Apr 13, 2026
N
Nordin
reacted to
KXP's post
in the thread
89 force tilt and trim valve body
with
Like
I went ahead and put the old o ring and the gasket and it worked it stayed up didn’t drop at all. Thanks
Apr 13, 2026
C
Crosbyman
No spark 55 HP Evinrude triumph 1969
spray some fuel in the carb while it cranks... if it fires up you have a fuel flow issue ... cylinder (s) not receiving fuel. the very...
Apr 13, 2026
6
68glasspar
You could try unplugging the round electrical connector on the engine to isolate the engine from the boat wiring. then jumper 12 volts...
Apr 13, 2026
6
68glasspar
So it did start and then die and not restart1! when it won't restart, do you still have spark at the plugs? spark should jump 3/8" at...
Apr 13, 2026
Not so sad boater
So I thought of that and I did replace the wires I actually ordered some stock replacements brand new place the distributor plugs plug...
Apr 13, 2026
M
Mc Tool
Ideas for planters/raised beds?
Um depends on your nutrient reserve , I had 2x 250L blue plastic drums that gravity feed thru the media into 2 more at the bottom ...
Apr 13, 2026
jimmbo
4 all y'all still shovelin snow
Made it it up to 16C today, -1 tonight, highs tomorrow 7 and rain, Wednesday 1 and snow.... not bad for April.
Apr 13, 2026
jimmbo
reacted to
tphoyt's post
in the thread
with
Like
I’m with ya there. I would much rather have to put on another layer to stay warm than be naked and burning up with no where to cool off.
Apr 13, 2026
M
MikeSchinlaub
Because it keeps the mycellium network intact, and makes for better moisture retention.
Apr 13, 2026
M
MikeSchinlaub
reacted to
alldodge's post
in the thread
with
Like
I know folks that do no till and have great growing every year. 30 inch wide for plants and 18 inch wide for walk way It takes a couple...
Apr 13, 2026
rolmops
StarCraft 181 SS conversion
Apr 13, 2026
Not so sad boater
reacted to
68glasspar's post
in the thread
with
Like
I went thru this very problem with my 1969 85hp evinrude last year! The info that Crosbyman gave you is top notch. Use it to get you to...
Apr 13, 2026
Apr 13, 2026
Mercruiser 350 MAG MPI
Your ECM post 4 shows the date of 2005 Being a 2005 your max WOT RPM is 4400-4800 per manual 31
Apr 13, 2026
