redneck joe
reacted to
piperjoe's post
in the thread
1973 Starcraft SuperSport 16ft. restoration questions
with
Like
Beautiful and sunny afternoon today and the snow is disappearing quickly. Lots of rain yesterday and last night with more on the way...
Apr 14, 2026
redneck joe
replied to the thread
Ideas for planters/raised beds?
Yes
Apr 14, 2026
redneck joe
reacted to
MikeSchinlaub's post
in the thread
with
Like
Because it keeps the mycellium network intact, and makes for better moisture retention.
Apr 14, 2026
F
froggy1150
Boat Cover Repair?
With the old singers there are belt drive and gear drive. I got the belt drive because thats what I found and I have a commercial...
Apr 14, 2026
M
Mc Tool
No spark 55 HP Evinrude triumph 1969
I get the feeling that there is more than one thing wrong with this motor.😁
Apr 14, 2026
bowler
Boat Cover Repair?
For sure. It's a beast! It was recommended to me by several sailors who had used it extensively. An elegant looking thing too!
Apr 13, 2026
Kola16
reacted to
Scott06's post
in the thread
Does This Sound Right? Bravo Install
with
Like
Could be the gimbal bearing is not fully seated
Apr 13, 2026
K
Kwanza
Alternator and fuel pump on Volvo Penta 3.0 GLP-D
Hi all, thank you everyone for your advice. Everyone's suggestions was acted upon, and investigated, (Lou C, alldodge, MarineSp...
Apr 13, 2026
jimmbo
And by Fuel, Premix @50:1
Apr 13, 2026
N
Nordin
1987 Force 50hp head warpage.
Yes like racerone says. Resurface it at a piece of glass and water sanding paper. sand it and do it in a 8 pattern way. Check it with a...
Apr 13, 2026
N
Nordin
reacted to
KXP's post
in the thread
89 force tilt and trim valve body
with
Like
I went ahead and put the old o ring and the gasket and it worked it stayed up didn’t drop at all. Thanks
Apr 13, 2026
C
Crosbyman
spray some fuel in the carb while it cranks... if it fires up you have a fuel flow issue ... cylinder (s) not receiving fuel. the very...
Apr 13, 2026
6
68glasspar
You could try unplugging the round electrical connector on the engine to isolate the engine from the boat wiring. then jumper 12 volts...
Apr 13, 2026
6
68glasspar
So it did start and then die and not restart1! when it won't restart, do you still have spark at the plugs? spark should jump 3/8" at...
Apr 13, 2026
Not so sad boater
So I thought of that and I did replace the wires I actually ordered some stock replacements brand new place the distributor plugs plug...
Apr 13, 2026
