T
tphoyt
reacted to
redneck joe's post
in the thread
Random
with
Like
Apr 14, 2026
tpenfield
replied to the thread
I/O (Sterndrive) Conversion to Outboards
I picked up the Hull & Deck Putty this AM . . . It is poly-based, but hopefully will be OK, considering I'll be scarf joining the...
Apr 14, 2026
redneck joe
Random
Apr 14, 2026
J
Jeff J
Paintball gun
Read Post #5. I haven’t killed a dog known to belong to a neighbor. A neighbor’s dog did get a chicken dinner. I haven’t seen that dog...
Apr 14, 2026
J
jitterbug127
Trailer Set Up
That's a lot of trailer for that little boat. I'd get a new winch post and go from there.
Apr 14, 2026
Scott06
No dipstick on 1989 era 3.0L?
excellent. Same here cut my teeth boat mechanic wise on my grandfathers 1966 Penn Yan that had the straight 6 (150 HP), the outdrive and...
Apr 14, 2026
Alternator and fuel pump on Volvo Penta 3.0 GLP-D
A fully charged resting Bat should read 12.7V that is after it has sat for an hour or so off the charger. Once motor has reved above...
Apr 14, 2026
J
Jeff J
Ideas for planters/raised beds?
Not everyone has dirt suitable for farming. Getting up and down, if able, also helps a person stay active and limber.
Apr 14, 2026
R
No spark 55 HP Evinrude triumph 1969
Do you have spark out of the coil?
Apr 14, 2026
D
DeepCMark58A
reacted to
Scott Danforth's post
in the thread
Paintball gun
with
Like
It's not the dogs fault it's out wandering
Apr 14, 2026
2000 Cruisers 2870 Check Engine light blinking but no codes?
Should be an MEFI ECM. you have to jump the pins to put it in diagnostic mode and read the flashes. you will need to get the VP MEFI...
Apr 14, 2026
CLi87
Just made it out to the boat, so I tested the oil pressure sensor, temp sensor and drive lube sensor by unplugging then to see if any...
Apr 14, 2026
Metal O-Ring appeared on alignment tool
thats a pull the gimbal bearing thing now. once the garter springs come off, you cant get them to stay on.
Apr 14, 2026
reacted to
Bondo's post
in the thread
with
Like
Ayuh,........ That is the tension spring from the gimbel bearing seal,.....
Apr 14, 2026
D
dypcdiver
I believe they call it a garter spring on the oil seal.
Apr 14, 2026
