further
replied to the thread
Metal O-Ring appeared on alignment tool
Thanks all. Got the gimbal bearing out and will replace. Having a bit of trouble pulling the seal. Any tips? Tried a 3 point seal...
Apr 14, 2026
redneck joe
Great loop speed record attempt
Some more prep work
Apr 14, 2026
J
JasonB
reacted to
airshot's post
in the thread
Stripped drain plug
with
Like
Is it a bronze plug ? If so, re tap the hole a size larger if threads are totally gone, the n get a bigger plug if there is enough...
Apr 14, 2026
I/O (Sterndrive) Conversion to Outboards
Guess I'll have to take you word for it. Being 2X the force than I don't see how the Crap --- arrel stays together going from a SSX 30...
Apr 14, 2026
redneck joe
Ideas for planters/raised beds?
Diatamacous earth, however it is spelled
Apr 14, 2026
redneck joe
Im a wee bit wobbly being a batchelor at the new house for a couple nights. I read the specs when im up tomorrow.
Apr 14, 2026
C
Chuck4741444
posted the thread
Motor lift plate
in
Johnson & Evinrude Outboards
I bought a c ouple of 96 johnson 200. They are 25 in. My boat is 20 in. I have found lift plates to raise it 5 inches, that are rated...
Apr 14, 2026
tpenfield
Good question and I am glad you asked . . . I can answer that with a series of drawings that track the forces created by the engines...
Apr 14, 2026
matt167
My carb is obsolete.. Please help me repair/replace!
Boats dot net has it in stock part number 8153. I assume it’s probably pretty easy to get one if they have it. But if you want to. Any...
Apr 14, 2026
No engineer here I'm seeing the many structural supports built into the OB structure. Don't see how that will ever have a chance of...
Apr 14, 2026
F
foste1cc
posted the thread
in
Mercury & Mariner Outboards
I have a new-to-me Mercury 18hp 2cyl 2-stroke (I think a 1980'-1985') Serial N: 6414331 I bought this to use as a kicker for my 21'...
Apr 14, 2026
tpenfield
A day of cutting and grinding . . . . I got a lot of the transom reinforcement structure cut . . . still a few more pieces to go. . ...
Apr 14, 2026
tpenfield
No I used the red & black measuring tape on both . . . Just a smidge off.
Apr 14, 2026
J
Jeff J
Egg shells scattered in the garden help keep the rabbits out. They don’t seem to like walking on them.
Apr 14, 2026
J
Jeff J
Paintball gun
Most paintball guns will be plenty accurate. Even the CO2 cartridge plastic pistols we started with in the late eighties were...
Apr 14, 2026
