P
Pmt133
reacted to
tpenfield's post
in the thread
I/O (Sterndrive) Conversion to Outboards
with
Like
A day of cutting and grinding . . . . I got a lot of the transom reinforcement structure cut . . . still a few more pieces to go. . ...
Apr 14, 2026
P
pae0332
replied to the thread
4.3 throttle dependent squeal - not belt related
good job, i pulled a completely rebuilt engine out of a boat cause i thought it was coming from the balance shaft bearing. its the only...
Apr 14, 2026
P
pae0332
why is there oil in my bellows but pressure test holds 15psi overnight
sealed bearing, no grease on bravos
Apr 14, 2026
S
saltchuckmatt
Motor lift plate
I've had, have two on my 115's I believe you order them based on your HP. I could be wrong
Apr 14, 2026
dwco5051
posted the thread
Is this considered as an outboard or !/O powered?
in
Dockside Chat
https://www.facebook.com/reel/1348914633728645
Apr 14, 2026
A
airshot
My carb is obsolete.. Please help me repair/replace!
In my opinion, nothing beats a good factory rebuild kit, thoroughly cleaned carb and reset to factory specs. Always worked well for me...
Apr 14, 2026
further
Metal O-Ring appeared on alignment tool
Thanks all. Got the gimbal bearing out and will replace. Having a bit of trouble pulling the seal. Any tips? Tried a 3 point seal...
Apr 14, 2026
redneck joe
Great loop speed record attempt
Some more prep work
Apr 14, 2026
J
JasonB
reacted to
airshot's post
in the thread
Stripped drain plug
with
Like
Is it a bronze plug ? If so, re tap the hole a size larger if threads are totally gone, the n get a bigger plug if there is enough...
Apr 14, 2026
Guess I'll have to take you word for it. Being 2X the force than I don't see how the Crap --- arrel stays together going from a SSX 30...
Apr 14, 2026
redneck joe
Ideas for planters/raised beds?
Diatamacous earth, however it is spelled
Apr 14, 2026
redneck joe
Im a wee bit wobbly being a batchelor at the new house for a couple nights. I read the specs when im up tomorrow.
Apr 14, 2026
C
Chuck4741444
posted the thread
Motor lift plate
in
Johnson & Evinrude Outboards
I bought a c ouple of 96 johnson 200. They are 25 in. My boat is 20 in. I have found lift plates to raise it 5 inches, that are rated...
Apr 14, 2026
tpenfield
Good question and I am glad you asked . . . I can answer that with a series of drawings that track the forces created by the engines...
Apr 14, 2026
matt167
Boats dot net has it in stock part number 8153. I assume it’s probably pretty easy to get one if they have it. But if you want to. Any...
Apr 14, 2026
