P
Pmt133
reacted to
Scott Danforth's post
in the thread
I/O (Sterndrive) Conversion to Outboards
with
Like
I have a 35 year old "Craftsman Pro" angle grinder which is a DeWalt with a black housing and Craftsman labels. its corded, and has...
Apr 15, 2026
J
Jakecsam
reacted to
Bondo's post
in the thread
Mercruiser Pre Alpha transom assembly
with
Like
Ayuh,...... No idea of what yer talking about,......
Apr 15, 2026
J
Jakecsam
replied to the thread
Yes the water tube, now I’m wondering if maybe the new style could work. I have all the it’s & bits for the new style
Apr 15, 2026
Apr 15, 2026
reacted to
alldodge's post
in the thread
Metal O-Ring appeared on alignment tool
with
Like
The ones I've worked on have been housing Manual says to remove with a slide hammer, but sometimes they get frozen
Apr 15, 2026
P
Pmt133
Are you talking about the water tube? At some point that got superseded to a plastic part... I'd swap to that if you wet store as they...
Apr 15, 2026
Apr 15, 2026
P
Pmt133
Love cordless tools. Had to go to air for mine as I kept burning them out. Obviously you have a wee bit less grinding to do than I did...
Apr 15, 2026
P
Pmt133
reacted to
tpenfield's post
in the thread
with
Like
Transom support structure is roughed out. . . Now onto the final grinding . . . Oh joy . . . :p . . My cordless angle grinder is...
Apr 15, 2026
Scott06
try a place like marineengine.com https://www.marineengine.com/parts/mercruiser-stern-drive/index.php you can search by drive/transom...
Apr 15, 2026
tpenfield
Apr 15, 2026
Apr 15, 2026
Ayuh,...... Does that seal load from the motor side of the housing,..??..??
Apr 15, 2026
Lou C
why is there oil in my bellows but pressure test holds 15psi overnight
boat's a 2009, did they start using sealed bearings that far back? Agree with turning the shafts when the pressure and vacuum tests are...
Apr 15, 2026
Don't see it being grease, that said the new bearings are sealed but there are thousands of the old style still out there that get greased
Apr 15, 2026
