C
Chuck4741444
replied to the thread
Motor lift plate
Thanks, im going to buy the lift
Apr 15, 2026
Scott06
why is there oil in my bellows but pressure test holds 15psi overnight
yes by 2009 they were sealed on new ones. My 2003 was still greased I think 2008 ish was cut over. Would entirely depend on when the...
Apr 15, 2026
FLATHEAD
My carb is obsolete.. Please help me repair/replace!
Better yet put ethanol free gas in it when you get it running. It’s what I use on all my stuff , boat,mower, chain saws, blower, weed...
Apr 15, 2026
K
kenny nunez
Is this considered as an outboard or !/O powered?
The ones I remember had a 6-71 Detroit coupled to a stern drive. 2 of them could actually plane off a barge. Most times they were...
Apr 15, 2026
FLATHEAD
That’s wild! Zoomed in Looks like his long tail mud motor has a busted prop.
Apr 15, 2026
J
jasonburba74
posted the thread
Mercruiser motor swap
in
Mercury MerCruiser Sterndrives & Engines
I was wonder if it is possible to swap motors in a 2008 Tahoe Q7i boat. I currently have a Mercruiser 4.3L and I would like to replace...
Apr 15, 2026
K
kenny nunez
Mercruiser Pre Alpha transom assembly
I have used a shock absorber grommet. Worked perfect. Be sure to put never seize on the threads that hold the flange down..
Apr 15, 2026
JASinIL2006
reacted to
aspeck's post
in the thread
cooking
with
Like
Her is one of 2 I did. The 2 fed 24 with leftovers. A coffee, garlic, onion, pepper and sea salt rub. Smoked with hickory for 4.5...
Apr 15, 2026
JASinIL2006
Pushing Run-Flat tires to the limit
We bought a new gas engine Honda CR-V last Fall. We really preferred the hybrid version, but they omitted the spare tire in order to...
Apr 15, 2026
JASinIL2006
Ideas for planters/raised beds?
I have used grow bags also, and my experience matched yours. They work great, especially because the plants don’t tend to get root bound...
Apr 15, 2026
tpenfield
reacted to
Pmt133's post
in the thread
I/O (Sterndrive) Conversion to Outboards
with
Like
My transom was so water logged it didn't matter. I've heard of using static guard or water mist though.
Apr 15, 2026
A
airshot
If you do proper maintenance it will be a long time before another rebuild will be needed. Watch where you buy your fuel, often times...
Apr 15, 2026
F
foste1cc
Thanks. Ordered a kit from boats dot net for around ~$75 shipped :/ But I guess it's better than +$100 🤷♂️ And also my own fault for...
Apr 15, 2026
P
Pmt133
Apr 15, 2026
F
foste1cc
reacted to
airshot's post
in the thread
with
Like
In my opinion, nothing beats a good factory rebuild kit, thoroughly cleaned carb and reset to factory specs. Always worked well for me...
Apr 15, 2026
