B
beta
replied to the thread
1995 Crownline 202BR Restore
Starting to clean up the gimbal housing, transom plate, etc and getting all the new gaskets, etc on order. Regarding the exhaust pipe...
Apr 15, 2026
B
beta
Took a vacation and got behind on posting. Completed the gel coating on the engine area. Did a dry fit on the the gimbal housing and...
Apr 15, 2026
F
foste1cc
reacted to
FLATHEAD's post
in the thread
My carb is obsolete.. Please help me repair/replace!
with
Like
Better yet put ethanol free gas in it when you get it running. It’s what I use on all my stuff , boat,mower, chain saws, blower, weed...
Apr 15, 2026
F
foste1cc
reacted to
airshot's post
in the thread
with
Like
If you do proper maintenance it will be a long time before another rebuild will be needed. Watch where you buy your fuel, often times...
Apr 15, 2026
Mercruiser motor swap
should be easy. however the boat is nearly 21 feet long. go with a 5.7 if you are sticking to Gen 1 SBC motor over the 5.0 @Scott06...
Apr 15, 2026
Pushing Run-Flat tires to the limit
AAA is an opt-in for most towing companies. they only get $35 per tow. so they are not really motivated.....
Apr 15, 2026
J
jlh3rd
Apr 15, 2026
W
Willyclay
reacted to
tpenfield's post
in the thread
I/O (Sterndrive) Conversion to Outboards
with
Like
I have both a cordless and corded angle grinders. Running 40 grit flap disks. . Progress so far . . . . . I've been using the...
Apr 15, 2026
W
Willyclay
reacted to
tpenfield's post
in the thread
with
Like
Here is the difference in those 2 boats (Formula 310 I/O vs OB) The outboard version has the hull extended at the full height of the...
Apr 15, 2026
C
Chuck4741444
Motor lift plate
Thanks, im going to buy the lift
Apr 15, 2026
Scott06
why is there oil in my bellows but pressure test holds 15psi overnight
yes by 2009 they were sealed on new ones. My 2003 was still greased I think 2008 ish was cut over. Would entirely depend on when the...
Apr 15, 2026
FLATHEAD
Apr 15, 2026
K
kenny nunez
Is this considered as an outboard or !/O powered?
The ones I remember had a 6-71 Detroit coupled to a stern drive. 2 of them could actually plane off a barge. Most times they were...
Apr 15, 2026
FLATHEAD
That’s wild! Zoomed in Looks like his long tail mud motor has a busted prop.
Apr 15, 2026
J
jasonburba74
posted the thread
in
Mercury MerCruiser Sterndrives & Engines
I was wonder if it is possible to swap motors in a 2008 Tahoe Q7i boat. I currently have a Mercruiser 4.3L and I would like to replace...
Apr 15, 2026
