C
ChadAustin
replied to the thread
Volvo aq270T gimbal bearing
Ok it looks to be fine, PDS fits well no slop, any chance that plate could cause massive vibration, I assume it’s the bearing but incase...
Apr 15, 2026
D
DeepCMark58A
2026 NFL/CFB News and Nonsense
Why would an average person know who that is or care? Not to be rude but who is that? Alex Smith my guess who has a very unremarkable...
Apr 15, 2026
A
airshot
Old 4hp Evinrude takes a nap
How accurate is your compression gage ? Did it over heat ? You might try some ring free or other additive to regain some compression.
Apr 15, 2026
M
Mc Tool
Nobody fishing?
It was blowing it arse off here today This is down at Howells point , Riverton and we are pointing straight at Stewart Island....,.if...
Apr 15, 2026
redneck joe
Random
https://www.facebook.com/share/v/1JkovcAhwt/
Apr 15, 2026
FLATHEAD
reacted to
tphoyt's post
in the thread
I’m still in the game
with
Like
A couple months ago durning a snow storm i stopped to help a lady change a tire. She went on her merry way and all was well. I was at...
Apr 15, 2026
S
saltchuckmatt
105 should still run
Apr 15, 2026
You can call it a splined thingy if it helps. A drive plate=damper=glorified clutch disc without friction material
Apr 15, 2026
redneck joe
If you are serious, I will post a synopsis.
Apr 15, 2026
B
BrianVT
This old 'rude looked pretty rough but I got it cheap. It had good compression (@ 120 psi on both, I think?). I hoped I could save it...
Apr 15, 2026
WIMUSKY
I give up, who is he?
Apr 15, 2026
C
Oil 4 stroke Mercury 115hp
That motor likely requires a FC-W oil. Any oil rated as such is acceptable. Automotive multivis oils are generally not recommended.
Apr 15, 2026
6
68glasspar
No spark 55 HP Evinrude triumph 1969
After dark have someone crank the engine over while you look under the flywheel and see if the spark is shorting thru the plug wire boots.
Apr 15, 2026
Not so sad boater
Using a timing light during cranking I only have signal at cylinder 1
Apr 15, 2026
A
airshot
Johnson 25 Prop size
On initial setup I always trim the motor so the cav plate is parallel to the bottom of the boat using a long straight edge. Put it up...
Apr 15, 2026
