P
Pmt133
replied to the thread
I/O (Sterndrive) Conversion to Outboards
36 grit belt on a belt sander worked well on flat surfaces FYI. May make short work of the outside.
Apr 16, 2026
P
Pmt133
reacted to
tpenfield's post
in the thread
with
Like
Interior grinding is done. I still have the grinding outside the transom to do . . .
Apr 16, 2026
P
Pmt133
Mercruiser motor swap
Once it was on plane ot was... fine. With 4 adults you were doing 24-26 mph without killing it with RPMs. I burn the same amount of fuel...
Apr 16, 2026
P
Pmt133
reacted to
Scott06's post
in the thread
with
Like
yes I had a 3.0 in a 17-18 ft bowrider. Wasnt really adequate there either, but I do miss putting $50 of gas in going all weekend and...
Apr 16, 2026
reacted to
tpenfield's post
in the thread
with
Like
Apr 16, 2026
tpenfield
Apr 16, 2026
roscoe
reacted to
Tdunne96's post
in the thread
Johnson 25 Prop size
with
Like
That is about what I expected 20-25. I get about 15-17 tops at the moment with only me on the boat. Supposed to clear up this weekend I...
Apr 16, 2026
yes, the Q7 did come with the 6.2 as an option. most of the motors were the 50 MPI engine, and some received the entry level 4.3...
Apr 16, 2026
Scott06
Apr 16, 2026
B
beta
1995 Crownline 202BR Restore
FYI... got an answer from the engine forum. It's 92-25234 Sound blanket glue, but this has been superseded by Bellows adhesive 86166Q1...
Apr 16, 2026
B
beta
Exhaust to Gimbal Connection
Thanks! I also see it now in the materials list but no mention of it in the instructions. There was a good bit of whatever was on it...
Apr 16, 2026
Alternator and fuel pump on Volvo Penta 3.0 GLP-D
Measuring the resistance of a blower tells you nothing. If you want to see how much current it is drawing use a DC clamp meter. As far...
Apr 16, 2026
P
Pmt133
The amount of restraint I exercised by only going to a V6 in my 4 winns needs to be studied. It was either 4.3 or 388, nothing else...
Apr 16, 2026
It just list to use it, no mention of how much I would probably use a liberal amount, won't hurt
Apr 16, 2026
Scott06
is that just to hold the oring/gasket in place?
Apr 16, 2026
