Not so sad boater
replied to the thread
No spark 55 HP Evinrude triumph 1969
Spark from coil wire jumps 1/2 nice blue spark. Extremely weak spark at plug #1 had to 1/8 from ground to get a spark. I have nothing at...
Apr 16, 2026
6
68glasspar
I wouldn't worry about timing until the engine runs
Apr 16, 2026
T
Toddavid
Power steering fluid in bilge?
Here’s a related question: why is the fluid red? The fluid in my reservoir and in the VP OE pint I bought are both yellowish/clear. I...
Apr 16, 2026
WIMUSKY
reacted to
redneck joe's post
in the thread
2026 NFL/CFB News and Nonsense
with
Like
Yes it is Alex Smith, and the injury almost killed him.
Apr 16, 2026
R
Old 4hp Evinrude takes a nap
Remove exhaust cover.----Look at pistons / rings.
Apr 16, 2026
R
Wave washer secures the rotor !----Rotor does not control timing.----Opening of breaker points controls timing
Apr 16, 2026
redneck joe
Ring Free question
Ok, im a fan of seafom as a starting point, ive gotten maybe a 75% success rate with it. If it burns offsh.y from the rings and...
Apr 16, 2026
6
68glasspar
You stated you had a slight wiggle on the rotor! Does the crankshaft have side play? If you have side play(excess play)that will affect...
Apr 16, 2026
6
68glasspar
You really need to find out if your spark is strong enough to start with! purchase an adjustable gap spark tester and set it to 3/8in...
Apr 16, 2026
A
airshot
When a motor gets to hot it can cause the excess carbon in the cylinders to become a goo....Sometimes after an overheat, a good cylinder...
Apr 16, 2026
A
airshot
reacted to
Chris1956's post
in the thread
My carb is obsolete.. Please help me repair/replace!
with
Like
Gee the first carb I saw clogged with varnish was in the fifty's. This was way before adding alcohol to gas was thought of. we also...
Apr 16, 2026
A
airshot
Ring Free question
Yep, it helps dissolve the carbon buildup on the pistons, heads and cylinders that can collect over time. Most outboard engine mfgrs...
Apr 16, 2026
454 Water pump hoses
The Volvo Penta water pump conversion is common. Normally the hoses to the exhaust are 3/4" or 1" Agree I. Posting a pic
Apr 16, 2026
J
Jagsvs
posted the thread
F9.9sk losing oil pressure
in
Yamaha & Suzuki Outboards
Hello this is my first post here but I’m having some real issues with this 1985 Yamaha f9.9sk. The motor had no oil pressure when I...
Apr 16, 2026
R
Run the carburetor empty when done.---A dry carburetor does not plug up.
Apr 16, 2026
