M
Mc Tool
replied to the thread
Old 4hp Evinrude takes a nap
Overheating can also cause the piston rings to loose tension which wont help compression 🙂
Apr 17, 2026
jimmbo
Johnson 25 Prop size
The may entail removal of the Carb, which then a check and possible adjustment known as a Link and Sync, will likely be in order...
Apr 16, 2026
Fun Times
Exhaust to Gimbal Connection
The cable seen in your first photo with the white wrap around it....The lower shift cable runs to the drive from the engine...Item...
Apr 16, 2026
B
beta
Not sure I know what you are referring to here.. can you elaborate?
Apr 16, 2026
Not so sad boater
No spark 55 HP Evinrude triumph 1969
I verified the gap on my points on all lobes twice just to be sure that nothing exceeded the recommended adjustment. I'm thinking I got...
Apr 16, 2026
Not so sad boater
No play in crank the wiggle is at the notched area it can turn side to side in the notch it sits in, my understanding is that it has...
Apr 16, 2026
Not so sad boater
Spark from coil wire jumps 1/2 nice blue spark. Extremely weak spark at plug #1 had to 1/8 from ground to get a spark. I have nothing at...
Apr 16, 2026
6
68glasspar
I wouldn't worry about timing until the engine runs
Apr 16, 2026
T
Toddavid
Power steering fluid in bilge?
Here’s a related question: why is the fluid red? The fluid in my reservoir and in the VP OE pint I bought are both yellowish/clear. I...
Apr 16, 2026
WIMUSKY
reacted to
redneck joe's post
in the thread
2026 NFL/CFB News and Nonsense
with
Like
Yes it is Alex Smith, and the injury almost killed him.
Apr 16, 2026
R
Remove exhaust cover.----Look at pistons / rings.
Apr 16, 2026
R
Wave washer secures the rotor !----Rotor does not control timing.----Opening of breaker points controls timing
Apr 16, 2026
redneck joe
Ring Free question
Ok, im a fan of seafom as a starting point, ive gotten maybe a 75% success rate with it. If it burns offsh.y from the rings and...
Apr 16, 2026
6
68glasspar
You stated you had a slight wiggle on the rotor! Does the crankshaft have side play? If you have side play(excess play)that will affect...
Apr 16, 2026
6
68glasspar
You really need to find out if your spark is strong enough to start with! purchase an adjustable gap spark tester and set it to 3/8in...
Apr 16, 2026
