2009 stingray
posted the thread
bravo bellows job, design #2 water intake hose question
in
Mercury MerCruiser Sterndrives & Engines
im doing bellows on a bravo 3, the water intake hose has the plastic section going into the housing and the rubber hose has a clamp...
Apr 18, 2026
BWR1953
reacted to
FLATHEAD's post
in the thread
Nobody fishing?
with
Like
In that picture It looks like the bail roller on the reel sits out to far as compared to the spool face allowing line to wrap around...
Apr 18, 2026
P
Pmt133
replied to the thread
I/O (Sterndrive) Conversion to Outboards
Epoxy over poly is fine. Poly and vinyl shouldn't go over epoxy. Gel can't go over epoxy either. There are bond coats that you can...
Apr 18, 2026
Merc 250 Verado Fuel increase
This was just because I was using the ladies pee jar. Verified it's clear and clean
Apr 18, 2026
P
Pmt133
reacted to
tphoyt's post
in the thread
with
Like
That a good plan Scott. I did that once in hopes that it would at least provide a wee bit of tooth. As far as the poly and epoxy being...
Apr 18, 2026
T
tphoyt
Apr 18, 2026
F9.9sk losing oil pressure
Don't know anything about the motor, but most oil pumps have the pressure regulator as part of the pump. Wonder if the Reg in yours is...
Apr 18, 2026
T
tphoyt
daily music fix
My mother would have told me that was the devils music. 😂
Apr 18, 2026
Maybe use a wire cup brush in the angle grinder to get in the crevices
Apr 18, 2026
redneck joe
I'd gring a wee bit more, up to a smidge....
Apr 18, 2026
redneck joe
daily music fix
If you are into jammin on keyboards https://www.facebook.com/share/v/1Ax99vbC41/
Apr 18, 2026
Would epoxy resin create a better hold?
Apr 18, 2026
tpenfield
I got my bolts, so the fastener portion of my installation is ready. I have been planning the adhesive aspect, being the hull & deck...
Apr 18, 2026
Don't think there is a fuse blown because when I switch to sport exhaust it does get louder, it just get completely quite when turned...
Apr 18, 2026
FLATHEAD
We had a bit of wind last night
Choose wisely. All the ash are now dead. Oak trees are now dying by the millions due to several diseases, and now there is a beach leaf...
Apr 18, 2026
