tpenfield
replied to the thread
I/O (Sterndrive) Conversion to Outboards
Since I'll be scarf joining and gelcoating, I chose to stay away from epoxy.
Apr 18, 2026
D
DeepCMark58A
Trail camera issues fixed, now pics from them ...
Saving a tree rat? Let nature run it's course.
Apr 18, 2026
Dukedog
2003 Mercury 200hp Saltwater edition 2 cycle, can the oiler be deleted?
yes, it can... like racer says, tha bleed stuff has absolutely nothin' ta do with tha oiler............ *justa note.. if you know tha...
Apr 18, 2026
C
Chuck4741444
posted the thread
Motor
in
Boat Restoration, Building, and Hull Repair
I have rebuild my transom on 1996 keener 21 ft CC then I Installed the motor, its not right because the left rear digs deep when...
Apr 18, 2026
P
Pmt133
reacted to
tpenfield's post
in the thread
with
Like
I'll try that . . . The main stringer is nothing but corduroy . . . :cautious: I did go back (just now) and hit some of the low spots...
Apr 18, 2026
tpenfield
Apr 18, 2026
2
2009 stingray
posted the thread
bravo bellows job, design #2 water intake hose question
in
Mercury MerCruiser Sterndrives & Engines
im doing bellows on a bravo 3, the water intake hose has the plastic section going into the housing and the rubber hose has a clamp...
Apr 18, 2026
BWR1953
reacted to
FLATHEAD's post
in the thread
Nobody fishing?
with
Like
In that picture It looks like the bail roller on the reel sits out to far as compared to the spool face allowing line to wrap around...
Apr 18, 2026
P
Pmt133
Epoxy over poly is fine. Poly and vinyl shouldn't go over epoxy. Gel can't go over epoxy either. There are bond coats that you can...
Apr 18, 2026
Merc 250 Verado Fuel increase
This was just because I was using the ladies pee jar. Verified it's clear and clean
Apr 18, 2026
P
Pmt133
reacted to
tphoyt's post
in the thread
with
Like
That a good plan Scott. I did that once in hopes that it would at least provide a wee bit of tooth. As far as the poly and epoxy being...
Apr 18, 2026
T
tphoyt
Apr 18, 2026
F9.9sk losing oil pressure
Don't know anything about the motor, but most oil pumps have the pressure regulator as part of the pump. Wonder if the Reg in yours is...
Apr 18, 2026
T
tphoyt
daily music fix
My mother would have told me that was the devils music. 😂
Apr 18, 2026
Maybe use a wire cup brush in the angle grinder to get in the crevices
Apr 18, 2026
