P
Pmt133
replied to the thread
I/O (Sterndrive) Conversion to Outboards
So the red... is that just the tooling resin from the mold?
Apr 19, 2026
P
Pmt133
reacted to
tpenfield's post
in the thread
with
Like
Day 3 (or 4) of grinding . . . . . A few more areas to do, but it is getting close.
Apr 19, 2026
C
Crosbyman
No spark 55 HP Evinrude triumph 1969
1968 version ?? in referrence to these "options" keep in mind anything affecting B+ fed to the amplifier is susceptible of interring...
Apr 19, 2026
tpenfield
Apr 19, 2026
matt167
posted the thread
Yamaha 9.9 troubles
in
Yamaha & Suzuki Outboards
My new boat ( 1989 Sylvan offshore ) came with a 2002 Yamaha 9.9 ( T9.9 ELRA high thrust ). Couple issues. It is pumping water but not...
Apr 19, 2026
F
fishbait2
2003 Mercury 200hp Saltwater edition 2 cycle, can the oiler be deleted?
I had called Mercury and that is what they told me. The 100:1 was at idle then increases to 50:1 at higher speeds. If not true please...
Apr 19, 2026
F
fishbait2
reacted to
Dukedog's post
in the thread
with
Like
yes, it can... like racer says, tha bleed stuff has absolutely nothin' ta do with tha oiler............ *justa note.. if you know tha...
Apr 19, 2026
C
Crosbyman
as a last resort and based on my own headnocks may I suggest you put this aside for a few days...if not a week and start with a new...
Apr 19, 2026
Davetowz
reacted to
danond's post
in the thread
decal removal
with
Like
Re: decal removal 3M adhesive remover kicks WD40's butt at goo removal.
Apr 19, 2026
Texasmark
Johnson 25 Prop size
I totally agree with what's shown in the picture as potentially being your problem. Let's assume that the mechanic that tested the...
Apr 19, 2026
R
Need to determine issue with top cylinder.----Fuel pump diaphragm ruptured??----Reed valve issue?
Apr 19, 2026
T
Tdunne96
When throttle is fully forward, the throttle linkage does max out but the throttle plate I can manually open a miniscule amount more by...
Apr 19, 2026
T
Tdunne96
Have new water pump kit, carb gasket kit, and oem prop on the way. 135 top and 130 bottom for compression. Both cylinders confirmed good...
Apr 19, 2026
D
DeepCMark58A
Just thought I'd share a nice photo.
My wife's uncle had a septic business and spread the contents of the "honey wagon" on his fields. I always joked the ears of corn in his...
Apr 19, 2026
C
Hard steering to the right
Do you have one of those Cobra Outdrives with a left handed prop? If so, it is common. Adjust the trim tab (anode) to make it steer...
Apr 19, 2026
