reacted to
tpenfield's post
in the thread
I/O (Sterndrive) Conversion to Outboards
with
Like
Day 3 (or 4) of grinding . . . . . A few more areas to do, but it is getting close.
Apr 19, 2026
reacted to
tpenfield's post
in the thread
with
Like
Apr 19, 2026
88 Capri (2022 SOTY)
replied to the thread
1989 omc cobra gear case problem
I'm no expert but these were a few thoughts I had, I'm about to put mine back together soon but I need to order a few more things yet.
Apr 19, 2026
dingbat
Ring Free question
Ring free is a Yamaha fuel additive recommended for daily use to prevent carbon buildup. It will not foul plugs when used as directed...
Apr 19, 2026
matt167
Yamaha 9.9 troubles
Literally cover the carb with my hand for a second and it pops off. I know it’s a primer system. I suspect it’s not working. As for the...
Apr 19, 2026
C
Crosbyman
No spark 55 HP Evinrude triumph 1969
if you have not done so yet u may want to post your problem question on AOMCI.org "ASK A QUESTION" maybe someone experienced it being...
Apr 19, 2026
B
boscoe99
Yamaha 9.9 troubles
What are you doing to manually choke the motor? That model does not have a mechanically activated choke plate. It uses a Yamaha...
Apr 19, 2026
Big Gee
reacted to
MikeSchinlaub's post
in the thread
Boats from work.
with
Like
The Cobalt and Stingray with locker damage are gone. I didn't take finished pics of the Cobalt, it's just white gel, but here is the pad...
Apr 19, 2026
flashback
reacted to
tpenfield's post
in the thread
with
Like
Apr 19, 2026
P
Pmt133
So the red... is that just the tooling resin from the mold?
Apr 19, 2026
P
Pmt133
reacted to
tpenfield's post
in the thread
with
Like
Apr 19, 2026
C
Crosbyman
1968 version ?? in referrence to these "options" keep in mind anything affecting B+ fed to the amplifier is susceptible of interring...
Apr 19, 2026
tpenfield
Apr 19, 2026
matt167
posted the thread
Yamaha 9.9 troubles
in
Yamaha & Suzuki Outboards
My new boat ( 1989 Sylvan offshore ) came with a 2002 Yamaha 9.9 ( T9.9 ELRA high thrust ). Couple issues. It is pumping water but not...
Apr 19, 2026
F
fishbait2
2003 Mercury 200hp Saltwater edition 2 cycle, can the oiler be deleted?
I had called Mercury and that is what they told me. The 100:1 was at idle then increases to 50:1 at higher speeds. If not true please...
Apr 19, 2026
