rolmops
replied to the thread
Changing a 22 foot Starcraft Islander from I/O to outboard with the engine hanging on a modified transom.
Going back and forth between changing to outboard or not, or selling and replacing with an outboard powered rig were just too many...
Apr 19, 2026
C
crazy charlie
posted the thread
Anyone have any experience selling items on Vinted?
in
Dockside Chat
Have been donating tons of clothing, many with tags, trying to see if I can make some gas money for the boat buy selling some. By the...
Apr 19, 2026
A
AusFox
Mercruiser 350 MAG MPI
Boat is running great! I just now want to put a fuel flow meter in and check the fuel consumption. It currently has a flow meter that’s...
Apr 19, 2026
matt167
Yamaha 9.9 troubles
I guess it might make sense that it’s been cooked as the rings could be hurt and still run well enough. I don’t have high hopes I guess...
Apr 19, 2026
A
airshot
reacted to
Texasmark's post
in the thread
Johnson 25 Prop size
with
Like
I totally agree with what's shown in the picture as potentially being your problem. Let's assume that the mechanic that tested the...
Apr 19, 2026
M
Mc Tool
No spark 55 HP Evinrude triumph 1969
Ah 🙂 now I dunno what to say . On one hand I think you will be over the moon happy when it goes but if its driving you nuts it might...
Apr 19, 2026
Not so sad boater
The first part of that makes a lot of sense trying to manually trigger the spark on certain cylinders so I might give that a shot...
Apr 19, 2026
matt167
Yamaha 9.9 troubles
Not sure as I haven’t checked it. I really don’t think it’s down on compression as it does actually run fine and has plenty of power. I...
Apr 19, 2026
C
Crosbyman
good or not here is one suggestion... disconnect the pulse wire from the points to the amplifier Position the rotor to fire on one...
Apr 19, 2026
M
Mc Tool
Yamaha 9.9 troubles
Sounds like its already been cooked . Whats the compression like ?
Apr 19, 2026
Not so sad boater
I did do this I just wanted to let you know I did not ignore your advice this is one of the things that I did when I went back into it...
Apr 19, 2026
Not so sad boater
I'm sorry I suffer from PTSD and I get really frustrated really easy I took my medicine so I've calmed down and been able to take a...
Apr 19, 2026
I/O (Sterndrive) Conversion to Outboards
Cruisers resin does have a reddish tint
Apr 19, 2026
Not so sad boater
reacted to
68glasspar's post
in the thread
with
Like
But you still refuse to spend 15min time and .05 cents worth of silcone dielectric inside the spark plug boot at the dist. cap!
Apr 19, 2026
Not so sad boater
I did do this since I already had the flywheel off it made it really easy for me to remove the boots and pack around the wire where it...
Apr 19, 2026
