R
replied to the thread
2003 Mercury 200hp Saltwater edition 2 cycle, can the oiler be deleted?
The Ford engine does not go from 600 to 6000RPM very often.----The outboard does when waterskiing or just playing.----Nor does the ford...
Apr 20, 2026
L
liusigou
my trolling motor ulterra stow issue
it seems the belt was damanged.
Apr 20, 2026
Not so sad boater
No spark 55 HP Evinrude triumph 1969
I mean do you even verify some of the information you share because it wants me to test the center post of my distributor if you knew...
Apr 20, 2026
Not so sad boater
Some of this information is incorrect The amplifier only provides 300 volts to the ignition coil and it's triggered by the points which...
Apr 20, 2026
What is the part number for this regulator?
test the regulator before trying to replace it. test the fuel pump output by itself.
Apr 20, 2026
Texasmark
I have had the same type of OEM oiler on 90 and 115 HP Mercs. Only difference is the posted range for these engines is 90 at idle to 50...
Apr 20, 2026
CLi87
posted the thread
in
Mercury MerCruiser Sterndrives & Engines
Hey all, i'm working on my 2000 Mercruiser 7.4 MPI and ran into a low fuel pressure condition, when I turn key on engine off pressure...
Apr 20, 2026
Anyone have any experience selling items on Vinted?
Wife buys and sells on poshmark. It has become her hobby.
Apr 20, 2026
C
Crosbyman
2nd part of documenet 🔥 Most likely causes (in order) 1) Distributor cap is leaking or internally shorted (MOST COMMON) Even if it...
Apr 20, 2026
C
Crosbyman
Sad boater here is an opinion, unbiased even if repetitive...from an intelligent source As you go down the list you will see a...
Apr 20, 2026
6
68glasspar
When i found the wires leaking on my 1969 85hp, it was a very very thin white arc, not a bright blue arc. i know you said you replaced...
Apr 20, 2026
FLATHEAD
Not selling. I have tried to buy on that site and never get any response from the sellers.
Apr 20, 2026
R
???----Post states---" normal start-up is a 100:1 "-----And I say it starts with what ever mixture is in the carburetors.----There is no...
Apr 20, 2026
dingbat
Ran a 1989 175 hp Merc on a boat I owned for 4 years. Put over 1,400 hours on the motor. Lost the high speed stator 20 miles out. Came...
Apr 20, 2026
FLATHEAD
reacted to
nola mike's post
in the thread
Ideas for planters/raised beds?
with
Like
Here, hold my beer...Just when you thought it couldn't get red-neckier. Got 2 canoes for $100. They aren't as deep as I had hoped (13")...
Apr 20, 2026
