R
reacted to
Crosbyman's post
in the thread
No spark 55 HP Evinrude triumph 1969
with
Like
I agree and indicated some info was incorrect .... AI is not perfect and as you found some info is not correct. I would love to assist...
Apr 20, 2026
replied to the thread
What is the part number for this regulator?
The manual covers testing the regulator and pump. I would follow the manual
Apr 20, 2026
C
Crosbyman
Apr 20, 2026
nola mike
2012 F150 3.5 EB turbo(2) oil change, low miles on oil
I wonder if we're going to see a spike in motor oil prices...
Apr 20, 2026
CLi87
How would you go about testing the regulator and fuel pump? I have the cool fuel system and the whole setup is in an assembly box that's...
Apr 20, 2026
6
68glasspar
Here's some things to consider! You cleaned the points, but didn't replace them. I believe the points are tungsten and you really don't...
Apr 20, 2026
R
2003 Mercury 200hp Saltwater edition 2 cycle, can the oiler be deleted?
The Ford engine does not go from 600 to 6000RPM very often.----The outboard does when waterskiing or just playing.----Nor does the ford...
Apr 20, 2026
L
liusigou
my trolling motor ulterra stow issue
it seems the belt was damanged.
Apr 20, 2026
Not so sad boater
I mean do you even verify some of the information you share because it wants me to test the center post of my distributor if you knew...
Apr 20, 2026
Not so sad boater
Some of this information is incorrect The amplifier only provides 300 volts to the ignition coil and it's triggered by the points which...
Apr 20, 2026
test the regulator before trying to replace it. test the fuel pump output by itself.
Apr 20, 2026
Texasmark
I have had the same type of OEM oiler on 90 and 115 HP Mercs. Only difference is the posted range for these engines is 90 at idle to 50...
Apr 20, 2026
CLi87
posted the thread
in
Mercury MerCruiser Sterndrives & Engines
Hey all, i'm working on my 2000 Mercruiser 7.4 MPI and ran into a low fuel pressure condition, when I turn key on engine off pressure...
Apr 20, 2026
Anyone have any experience selling items on Vinted?
Wife buys and sells on poshmark. It has become her hobby.
Apr 20, 2026
C
Crosbyman
2nd part of documenet 🔥 Most likely causes (in order) 1) Distributor cap is leaking or internally shorted (MOST COMMON) Even if it...
Apr 20, 2026
