M
Mc Tool
replied to the thread
daily music fix
https://share.google/LhOdBltLCnJnjofMD
Apr 20, 2026
M
Mc Tool
reacted to
redneck joe's post
in the thread
daily music fix
with
Like
There are a few songs that when I hear them I can feel by body change. Wife says she can see it when I get in the boat as we pull away...
Apr 20, 2026
J
jlh3rd
Need help finding tachometer
I can't tell what #of pins in your plug end. Various cables out there. Grey is a tach wire. Maybe 5 wires?...pins? so, yes, you need a...
Apr 20, 2026
Dukedog
2003 Mercury 200hp Saltwater edition 2 cycle, can the oiler be deleted?
injection.... bleed is removing puddling/excess fuel... mostly at idle and/or lower rpm.
Apr 20, 2026
Dukedog
boy! you cats are strange.............................. "fence post anyone?"
Apr 20, 2026
B
boscoe99
Apr 20, 2026
C
Crosbyman
No spark 55 HP Evinrude triumph 1969
if you have learned more than AI that is progress. I suggest you link up with chatgpt and being specific about the 69 55HP mdl yoy have...
Apr 20, 2026
B
boscoe99
Which depends upon the amount of oil that has been injected into the gasoline supply by the variable output oil pump.
Apr 20, 2026
B
boscoe99
Like underwear for old folks, it depends. If the motor has been idling prior to shut down then the ratio of oil would have been 100/1...
Apr 20, 2026
R
I worked at a dealer where we sold those motors NEW.-----Can rebuild engine and lower unit without using / needing a manual.
Apr 20, 2026
Not so sad boater
My dog got ahold of it so it now has a damaged plastic end where the boot goes. But I think I'm going to try it anyway if it acts any...
Apr 20, 2026
Mercruiser 5 L mpi cooling system
flappers and the rubber exhaust couplings. both rated to 250F max. however without water running, your exhaust goes from 200F to 950F
Apr 20, 2026
Not so sad boater
I wasn't trying to be rude. You kept supplying information not related to the engine at all, so all though you were trying to be helpful...
Apr 20, 2026
Not so sad boater
I did look for new points on eBay and I thought about buying them because besides the points would have to be a bad new part. The ends...
Apr 20, 2026
A
affa
Ok thanks, the rubber in the exhaust, is that the flappers?
Apr 20, 2026
