Not so sad boater
replied to the thread
No spark 55 HP Evinrude triumph 1969
I didn't get anything on ac I had it on the wrong setting earlier when I was testing. I don't mind spending the $30 for the adapter. I...
Apr 20, 2026
S
Sam. M
reacted to
redneck joe's post
in the thread
What Thrust Size Trolling Motor?
with
Like
Honestly not used a whole bunch but I could probably troll at 1 to 1.5 mph if I didn't want to use my main 50HP. Mine is a tiller...
Apr 20, 2026
6
68glasspar
If you have a desktop computor, follow this link to a manual put out by CDi electronic...
Apr 20, 2026
6
68glasspar
If your not using a DVA adaptor, then test on ac voltage
Apr 20, 2026
S
Sam. M
posted the thread
1965 starcraft nassau transom
in
Starcraft Boats
I have a16 ft. 1965 starcraft nassau and the transom was mostly removed and rotted out and i have no idea how to make a template. Does...
Apr 20, 2026
Not so sad boater
I have to admit that I have asked AI some questions, according to it the type of diodes are electrolytic or something like that and...
Apr 20, 2026
Not so sad boater
DC my meter can read up to 600 it's a Klein but doesn't have the built in DVA like some do.
Apr 20, 2026
6
68glasspar
are you testing for ac or dc voltage cd box to coil?
Apr 20, 2026
baconbiscut
posted the thread
New SEI drive, need a new prop.
in
Prop Questions and Topics
I have an early 70s 17' Dixie Trihull with the Mercruiser 140. I recently installed a new SEI drive because the old drive had a very...
Apr 20, 2026
A
airshot
Stoked
From someone that has been there.... Take the retirement when you can....we have no idea what the future holds !! We planned for our...
Apr 20, 2026
Not so sad boater
reacted to
68glasspar's post
in the thread
with
Like
You have 1 wire going from the points to the cd box, but there is another wire coming out from under the cap that makes a ground for the...
Apr 20, 2026
Not so sad boater
And no I thought it did but I just looked it up and it doesn't have it built in, I used it while I was a mechanic. I will get one. I did...
Apr 20, 2026
J
Jmunk
Mercruiser 5 L mpi cooling system
How long did you run it without a hose feeding in water?
Apr 20, 2026
J
jason stu
Suzuki df200ap 2021 outboard thermostat
was OEM $62 - Suzuki parts come from Japan-
Apr 20, 2026
T
tphoyt
reacted to
DeepCMark58A's post
in the thread
Stoked
with
Like
Change in my job responsibilities. I will be working from home, same salary, same all expense paid company vehicle, same deluxe...
Apr 20, 2026
