J
Jmunk
replied to the thread
Mercruiser 5 L mpi cooling system
No water came out due to the fact there wasn’t any water pressure to push it out. Best case it’s just the flappers and rubber couplers...
Apr 21, 2026
dingbat
Which kicker mount to install?
Not worth the extra expense for trolling use. Back up only works on lakes and only if you run separate fuel supplies to prevent cross...
Apr 21, 2026
Grub54891
reacted to
redneck joe's post
in the thread
Random
with
Like
Apr 21, 2026
Grub54891
Random
I do not like green eggs and ham. Or liquids!
Apr 21, 2026
redneck joe
1965 starcraft nassau transom
Instead of cardboard I'd use luan / floor underlayment. One piece, more stiff.
Apr 21, 2026
J
jlh3rd
New SEI drive, need a new prop.
by book #'s : Dropping pitch by 2 inches raises WOT rpm's by 300-400 rpm's. Then adding a blade can reduce rpm's by 100-150..200 rpm's...
Apr 21, 2026
redneck joe
reacted to
airshot's post
in the thread
Stoked
with
Like
From someone that has been there.... Take the retirement when you can....we have no idea what the future holds !! We planned for our...
Apr 21, 2026
redneck joe
daily music fix
Wee blonde chicks are never a bad thing.
Apr 21, 2026
dingbat
reacted to
alldodge's post
in the thread
Odyssey Bats
with
Like
Sorry off one digit 100 Ah so 10% is 10 amp
Apr 21, 2026
5-10 seconds is max to run without water. at 5-10 minutes, you definitely burned up the flappers and most likely the rubber connectors.
Apr 21, 2026
What is the part number for this regulator?
unplug the vacuum line to the regulator. fuel pressure should spike to about 50 psi. if the fuel doesnt spike, look at the pump or the...
Apr 21, 2026
dingbat
reacted to
DeepCMark58A's post
in the thread
Stoked
with
Like
Change in my job responsibilities. I will be working from home, same salary, same all expense paid company vehicle, same deluxe...
Apr 21, 2026
tpenfield
hjelp mercruser 350 med sift, har byttet til thunderboltlv elektronisk fordeler.....
Looks like this is the translation . . . I’ve switched to a Thunderbolt LV electronic distributor… it won’t start… it’s only sputtered...
Apr 21, 2026
Ayuh,...... Welcome Aboard,.... Can you translate that to english,..??..??
Apr 21, 2026
CLi87
I have the service manual for the 7.4 MPI and in the diagnostic flowchart it just says check for fuel pressure and if not correct, go to...
Apr 21, 2026
