D
DeepCMark58A
replied to the thread
Stoked
Well health wise thanks to the liver issues I have had I had over 50 different tests and procedures checked everything I am pretty...
Apr 21, 2026
C
Chuck4741444
Motor
I can see if the holes are centered on the transon, making sure the motor Is centered horizontaly, just pulled the old motor. Im...
Apr 21, 2026
redneck joe
reacted to
piperjoe's post
in the thread
1973 Starcraft SuperSport 16ft. restoration questions
with
Like
62 degrees and rising along with a beautiful blue sky and sunny day! I’ll be climbing into the boat today if all goes well. Sure...
Apr 21, 2026
redneck joe
reacted to
Lpgc's post
in the thread
I/O (Sterndrive) Conversion to Outboards
with
Like
I'm not sure what the order is hehe
Apr 21, 2026
sad boater
No spark 55 HP Evinrude triumph 1969
My understanding is that these old parts could run forever unless they were underpowered overpowered or not powered at all. I have a...
Apr 21, 2026
C
Chuck4741444
posted the thread
Prop Rotation
in
Johnson & Evinrude Outboards
I bought 2 96 johnson 200 Model # j200txedr # j2000xedr My research shows they are both clockwise, standard rotation. I...
Apr 21, 2026
A
affa
Mercruiser 5 L mpi cooling system
Are there any problem using the boat with worn out flappers?
Apr 21, 2026
R
robinfla52
posted the thread
Mercury 5 HP 4-stroke won't start
in
Mercury & Mariner Outboards
I actually have a Tohatsu MFS5C. New carb, fuel pump, spark plug. Spark is strong. I spray fuel into spark plug hole, put plug back in...
Apr 21, 2026
Scott06
Alpha one gen 2 - retaining ring/sleeve came out
on a gen 2 I dont think there is glue on that side of bellows. you can just put a new retaining ring in, but I would check the bellows...
Apr 21, 2026
R
1988 Johnson 15 won’t stay running….
I always ask folks to post the actual compression values,----Need to establish condition of the engine,-----Where did you purchase the...
Apr 21, 2026
J
Jordankato
posted the thread
in
So I just came across a 1988 15 hp Johnson outboard and I know it started and ran before I got it. I put a whole new fuel pump on it...
Apr 21, 2026
jimmbo
I have a Heathkit Stereo I built in 1975, it has several dozen Electrolytic Capacitors in it, and it still works...
Apr 21, 2026
sad boater
That makes sense, it was AI which gave me that info. I don't necessarily trust AI I had to correct it a bunch of times. It was kinda...
Apr 21, 2026
jimmbo
I think you mean Electrolytic Capacitors, they can dry out over long Periods of Time. While there is such a thing as an Electrolytic...
Apr 21, 2026
FLATHEAD
Stoked
Yes this /\. I got out of the rat race at 62. To be honest I would probably still be working if I didn’t have a stroke at 61.( Thanks...
Apr 21, 2026
