replied to the thread
Mercruiser 5 L mpi cooling system
usually the burned flappers drop down the Y-pipe, plug exhaust causing the motor to run like crap, then the flapper pin wears a hole in...
Apr 21, 2026
Fun Times
reacted to
Scott06's post
in the thread
Alpha one gen 2 - retaining ring/sleeve came out
with
Like
on a gen 2 I dont think there is glue on that side of bellows. you can just put a new retaining ring in, but I would check the bellows...
Apr 21, 2026
Lou C
Well, it's hard to say, but if the static water line is just high enough with no safety margin it is possible to get water up the...
Apr 21, 2026
W
Willyclay
reacted to
redneck joe's post
in the thread
I/O (Sterndrive) Conversion to Outboards
with
Like
Ted must be busy grinding
Apr 21, 2026
W
Willyclay
reacted to
Lpgc's post
in the thread
with
Like
Heh, I already knew all these words ;) There's also a gnat's arse (or other body parts), a titchy bit, etc.
Apr 21, 2026
redneck joe
Apr 21, 2026
redneck joe
reacted to
Scott Danforth's post
in the thread
with
Like
there are two scales.....
Apr 21, 2026
Apr 21, 2026
reacted to
aspeck's post
in the thread
with
Like
Don't forget a "whisker" a skosh, and a "mere pittance"
Apr 21, 2026
D
DeepCMark58A
Stoked
Well health wise thanks to the liver issues I have had I had over 50 different tests and procedures checked everything I am pretty...
Apr 21, 2026
C
Chuck4741444
Motor
I can see if the holes are centered on the transon, making sure the motor Is centered horizontaly, just pulled the old motor. Im...
Apr 21, 2026
redneck joe
reacted to
piperjoe's post
in the thread
1973 Starcraft SuperSport 16ft. restoration questions
with
Like
62 degrees and rising along with a beautiful blue sky and sunny day! I’ll be climbing into the boat today if all goes well. Sure...
Apr 21, 2026
redneck joe
reacted to
Lpgc's post
in the thread
with
Like
I'm not sure what the order is hehe
Apr 21, 2026
sad boater
No spark 55 HP Evinrude triumph 1969
My understanding is that these old parts could run forever unless they were underpowered overpowered or not powered at all. I have a...
Apr 21, 2026
C
Chuck4741444
posted the thread
Prop Rotation
in
Johnson & Evinrude Outboards
I bought 2 96 johnson 200 Model # j200txedr # j2000xedr My research shows they are both clockwise, standard rotation. I...
Apr 21, 2026
