R
robinfla52
replied to the thread
Mercury 5 HP 4-stroke won't start
I totally agree with you. That's what I don't understand, I take the plug out and ground it and pull cord and I get blue spark. I am...
Apr 21, 2026
roscoe
Hot water heater
I don’t have on demand, I have tankless. So far so good, but only had it for 18 months.
Apr 21, 2026
Stinnett21
New SEI drive, need a new prop.
17" 3 blade, in the same prop brand/style, should put you right where you need to be. Instead of a hydrofoil consider Nauticus Smart tabs.
Apr 21, 2026
redneck joe
reacted to
baconbiscut's post
in the thread
with
Like
Thanks for the advisement. I've done plugs cap and rotor last season but didn't mess with the timing or the carb as it runs so well...
Apr 21, 2026
P
Pmt133
reacted to
baconbiscut's post
in the thread
with
Like
Apr 21, 2026
P
Pmt133
reacted to
tpenfield's post
in the thread
I/O (Sterndrive) Conversion to Outboards
with
Like
I am glassing today . . . not quite warm enough, but I got a heater going and using 2.25% MEKP . . . seems to be working . . . but it is...
Apr 21, 2026
J
Jordankato
reacted to
racerone's post
in the thread
1988 Johnson 15 won’t stay running….
with
Like
I always ask folks to post the actual compression values,----Need to establish condition of the engine,-----Where did you purchase the...
Apr 21, 2026
baconbiscut
Apr 21, 2026
J
Jordankato
The carburetor got ruined. In the brass plate, a screw stripped out and couldn’t be easy outed. As for the fuel pump, I probably...
Apr 21, 2026
T
tphoyt
Random
That’s what it’s like to talk with my farther in-law sometimes.
Apr 21, 2026
O
omc cobra guy
posted the thread
Hot water heater
in
Non-Boating Technical Topics
Its time for a new hot water heater Im thinking about a on-demand water heater has anyone done it? Hows it working out?
Apr 21, 2026
C
if it doesn't pop with starting fluid, you do not have any spark. period
Apr 21, 2026
D
DeepCMark58A
reacted to
Scott Danforth's post
in the thread
Stoked
with
Like
I need a gig like that.
Apr 21, 2026
reacted to
in the thread
Mercruiser 5 L mpi cooling system
with
Like
usually the burned flappers drop down the Y-pipe, plug exhaust causing the motor to run like crap, then the flapper pin wears a hole in...
Apr 21, 2026
reacted to
Lou C's post
in the thread
with
Like
Well, it's hard to say, but if the static water line is just high enough with no safety margin it is possible to get water up the...
Apr 21, 2026
