J
Jordankato
reacted to
jitterbug127's post
in the thread
1988 Johnson 15 won’t stay running….
with
Like
I ran into this last summer on a 15 i had. I'd start with checking your low speed needle on the carb. It needs to be around 1.5 turns...
Apr 21, 2026
aspeck
reacted to
redneck joe's post
in the thread
I/O (Sterndrive) Conversion to Outboards
with
Like
Or the proverbial 'hair'
Apr 21, 2026
R
replied to the thread
Does spark jump a gap of 3/8" on both leads ?----Checked reed valves ?
Apr 21, 2026
D
Dannysmyk
reacted to
ESGWheel's post
in the thread
1981 MerCruiser 120 tick/ squeak
with
Like
Oh boy. Excessive blowby is a sign of piston rings not sealing. My new suggestion is to also do a (warm) compression test and post results.
Apr 21, 2026
J
jitterbug127
Apr 21, 2026
New SEI drive, need a new prop.
Unless you swapped to a Voyager EST distributor, you have points. The dwell and timing is an every year thing
Apr 21, 2026
D
Dannysmyk
Hi all. The season is here and finally got her out of storage. 2 cranks and fired right up. Cold compression readings prior to start...
Apr 21, 2026
R
Mercury 5 HP 4-stroke won't start
Does spark jump a gap of 3/8" (9 mm ) on a test device?
Apr 21, 2026
Lou C
Mercruiser 5 L mpi cooling system
I had to pull the outdrive to get the rest of the burned up flappers out they were in the exhaust passage, lucky the pins stayed where...
Apr 21, 2026
R
robinfla52
I totally agree with you. That's what I don't understand, I take the plug out and ground it and pull cord and I get blue spark. I am...
Apr 21, 2026
roscoe
Hot water heater
I don’t have on demand, I have tankless. So far so good, but only had it for 18 months.
Apr 21, 2026
Stinnett21
17" 3 blade, in the same prop brand/style, should put you right where you need to be. Instead of a hydrofoil consider Nauticus Smart tabs.
Apr 21, 2026
redneck joe
reacted to
baconbiscut's post
in the thread
with
Like
Thanks for the advisement. I've done plugs cap and rotor last season but didn't mess with the timing or the carb as it runs so well...
Apr 21, 2026
P
Pmt133
reacted to
baconbiscut's post
in the thread
with
Like
Apr 21, 2026
P
Pmt133
reacted to
tpenfield's post
in the thread
with
Like
I am glassing today . . . not quite warm enough, but I got a heater going and using 2.25% MEKP . . . seems to be working . . . but it is...
Apr 21, 2026
