O
omc cobra guy
replied to the thread
Hot water heater
Apr 21, 2026
O
omc cobra guy
Hot water heater
Their not the same?
Apr 21, 2026
M
Mc Tool
Mercury 5 HP 4-stroke won't start
Stuck valve ? Stick your finger in the plug hole ,give it a pull on the starter and see if there is any compression . 2nd line original...
Apr 21, 2026
S
saltchuckmatt
Prop Rotation
With the motor off, pull the plugs, put it in gear...and turn the flywheels clockwise while observing the prop shafts. To answer your...
Apr 21, 2026
S
saltchuckmatt
1988 Johnson 15 won’t stay running….
Lots of terms I've never heard of. To answer racer question, were the parts ordered OEM? Also, there was a 10 lb difference in the...
Apr 21, 2026
8
83bluefin
1983 Blue Fin 16’ Resto
Right now I think the transom is OK. It ends above the floor and after yanking on the outboard with the tilt locked in the upright...
Apr 21, 2026
CLi87
What is the part number for this regulator?
Ok, I assume this is with engine running and not just key on engine off? I'll do the test hopefully tomorrow if I have time to make it...
Apr 21, 2026
Dukedog
2003 Mercury 200hp Saltwater edition 2 cycle, can the oiler be deleted?
see post #14...................
Apr 21, 2026
roscoe
reacted to
bajaman123's post
in the thread
Hot water heater
with
Like
water heater
Apr 21, 2026
F
fishbait2
reacted to
Texasmark's post
in the thread
with
Like
I have had the same type of OEM oiler on 90 and 115 HP Mercs. Only difference is the posted range for these engines is 90 at idle to 50...
Apr 21, 2026
F
fishbait2
reacted to
Dukedog's post
in the thread
with
Like
tamatoes, tamotoes.... off course it gonna start with what evers in it.... tha ecu has absolutely nothin' ta do with tha oiler...
Apr 21, 2026
F
fishbait2
reacted to
racerone's post
in the thread
with
Like
I stated that there is no ECU on the motor.----Motor starts /runs on the mix ratio that is in the carburetors!
Apr 21, 2026
F
fishbait2
reacted to
Dukedog's post
in the thread
with
Like
injection.... bleed is removing puddling/excess fuel... mostly at idle and/or lower rpm.
Apr 21, 2026
F
fishbait2
Bleed
Apr 21, 2026
F
fishbait2
reacted to
boscoe99's post
in the thread
with
Like
Like underwear for old folks, it depends. If the motor has been idling prior to shut down then the ratio of oil would have been 100/1...
Apr 21, 2026
