flashback
replied to the thread
Hot water heater
Likely the existing 240v circuit, if existing heater is electric, will not be sufficient.
Apr 22, 2026
flashback
reacted to
jlh3rd's post
in the thread
Hot water heater
with
Like
read up on installation costs and requirements.
Apr 22, 2026
R
Is there such a thing as peeing too hard?
What is the water pressure on that hose?-----Test it on the lake I say.
Apr 22, 2026
R
Mercury 5 HP 4-stroke won't start
You have no spark or spark at the wrong time !!!!
Apr 22, 2026
C
there are rare cases where the spark plug is broken, or doesn't make a good ground to the head. make sure both are clean
Apr 22, 2026
R
robinfla52
Anybody think I should take to a professional. I might still be able to make some money from it if I get it running. Only have $200 invested
Apr 22, 2026
R
robinfla52
I have compression. Last night when it was darker I could see bright spark in tester and on plug itself. I used a dva to measure voltage...
Apr 22, 2026
L
Lpgc
reacted to
Scott Danforth's post
in the thread
What is the part number for this regulator?
with
Like
unplug the vacuum line to the regulator. fuel pressure should spike to about 50 psi. if the fuel doesnt spike, look at the pump or the...
Apr 22, 2026
L
Lpgc
reacted to
in the thread
with
Like
Unplugging the vacuum to the regulator is the test.
Apr 22, 2026
C
the device is called a telltale, because you can see it. It does not affect cooling.
Apr 22, 2026
C
if a valve was stuck, and spark was present, the engine would backfire or catch on fire. your spark is going away under compression or...
Apr 22, 2026
L
Lpgc
I'm not too familiar with marine applications but you seem to be describing a simple mechanical fuel pressure regulator setup similar to...
Apr 22, 2026
D
DeepCMark58A
Boat transport
It is also a fun adventure to go by water, you need experience to do that though. I have gone from Pickwick TN to Florida and back a...
Apr 22, 2026
D
DeepCMark58A
Boat transport
If the boat is sitting at a marina the people there will have trusted contacts, but still trust and verify.
Apr 22, 2026
R
Boat transport
Total distance involved?----Moving it from where to where?
Apr 22, 2026
