M
Mc Tool
reacted to
racerone's post
in the thread
Mercury 5 HP 4-stroke won't start
with
Like
Remove valve cover.----Check valve operation / clearance.
Apr 22, 2026
redneck joe
replied to the thread
Random
I miss The Orville https://www.facebook.com/share/r/18MMhwfBY2/
Apr 22, 2026
K
KenOverton33
1982 9.8HP gears issue
Even though the gear ID at the rear is smaller on the original, I'm sure it won't matter, as the bearing is supported by the bearing...
Apr 22, 2026
C
Crosbyman
Prop Rotation
it is simple 96 johnson 200 Model # j200txedr & # j2000xedr You’ve got two model numbers there, but one of them is likely a...
Apr 22, 2026
T
tphoyt
Milky oil
If you still have the oil you took out let it settle for a few days and see how it looks.
Apr 22, 2026
bajaman123
Power steering fluid in bilge?
In my case, because it was SUCH a mess, I dumped in two gallons of SUPERCLEAN, about a half-bottle of Dawn, and then blasted in about 30...
Apr 22, 2026
R
Apr 22, 2026
Blessed
IMO be very thankful for any kind COLA Wife retired from KY state Teachers system in 2010, she has received 1 COLA in 2011 and that's...
Apr 22, 2026
2002 Four Winns 214 Funship
FourWinns simply bought a sink. They are not brand specific. Check Great Lakes Skipper Also check the RV sites, as things like sinks...
Apr 22, 2026
FLATHEAD
Blessed
Isn’t that the truth
Apr 22, 2026
Fun Times
What is the part number for this regulator?
Because there are two of them for the marine version the regulator you found on top of the engine is more so considered to be a fuel...
Apr 22, 2026
V
void7910
Alpha one gen 2 - retaining ring/sleeve came out
Thanks! I get the boat out of storage next week, will double check what the inside of the bellows attachment to the bell housing looks...
Apr 22, 2026
flashback
Blessed
I took mine at 65 as I need it, my biggest complaint is the so called COLA.
Apr 22, 2026
Lou C
99 Volvo 5.0GL
How old is the fuel in the tank, straight gas or E10? Reason why I ask is that last season, for the first time I had gas go bad on me...
Apr 22, 2026
Kla
posted the thread
in
Boat Topics and Questions (not engine topics)
Hello y'all. I've been a member here for a few years but haven't been very active. I've been looking for an original sink bowl for this...
Apr 22, 2026
