H
highpowerdad
posted the thread
Rear main seal on 5.7 GXI
in
Volvo Penta I/O & Inboard Gas Engines & Outdrives
So... pulled the coupler off - the one that was bent - and while I was there, I figured I might as well pull the flywheel off and look...
Apr 22, 2026
A
aidanmurphy
posted the thread
Cracked bearing carrier, run or replace?
in
Mercury & Mariner Outboards
Cracked my bearing carrier putting it back onto the lower after pressing in the new prop shaft seals. Ordering a new carrier but any...
Apr 22, 2026
CLi87
replied to the thread
What is the part number for this regulator?
I just bought a new fuel pump and it should be here Saturday so I'll install it and hopefully that fixes my problem, thanks!
Apr 22, 2026
CLi87
Thanks! I'll definitely get one of those, can't believe they want over $500 for the OEM Mercruiser one, why is that one so much more...
Apr 22, 2026
R
Prop Rotation
And here I thought the letter----N----was for counter rotation in the 96 model year.
Apr 22, 2026
M
Mc Tool
reacted to
redneck joe's post
in the thread
Random
with
Like
Only minus 3? Tis but a flesh wound....
Apr 22, 2026
Kla
2002 Four Winns 214 Funship
I've checked Great Lakes Skipper already but haven't found one that matches up. Never thought of RV sites. Will definitely check some...
Apr 22, 2026
matt167
Yamaha 9.9 troubles
The one I have just has many signs of being a worn out high hour motor when you look close. I missed it when I bought it truthfully as...
Apr 22, 2026
M
Mc Tool
Mercury 5 HP 4-stroke won't start
Yep ,if one of them is stuck it will have way to much valve clearance .....but if you do have compression they aint stuck . Usually its...
Apr 22, 2026
M
Mc Tool
reacted to
racerone's post
in the thread
with
Like
Remove valve cover.----Check valve operation / clearance.
Apr 22, 2026
redneck joe
Random
I miss The Orville https://www.facebook.com/share/r/18MMhwfBY2/
Apr 22, 2026
K
KenOverton33
1982 9.8HP gears issue
Even though the gear ID at the rear is smaller on the original, I'm sure it won't matter, as the bearing is supported by the bearing...
Apr 22, 2026
C
Crosbyman
Prop Rotation
it is simple 96 johnson 200 Model # j200txedr & # j2000xedr You’ve got two model numbers there, but one of them is likely a...
Apr 22, 2026
T
tphoyt
Milky oil
If you still have the oil you took out let it settle for a few days and see how it looks.
Apr 22, 2026
bajaman123
Power steering fluid in bilge?
In my case, because it was SUCH a mess, I dumped in two gallons of SUPERCLEAN, about a half-bottle of Dawn, and then blasted in about 30...
Apr 22, 2026
