C
Crabeye
replied to the thread
1982 starcraft v220 mariner v5 potential rebuild
WELL...I am ready to get said rivets set and now have just acquired a 21ft. Duckworth welded boat!! So beleive i am going to put my 1983...
Apr 23, 2026
R
robinfla52
Mercury 5 HP 4-stroke won't start
All good
Apr 23, 2026
R
Cracked bearing carrier, run or replace?
Maybe reverse gear was not lined up with pinion.----Slow rotation of crankshaft while slowly tightening might be the way to go.
Apr 23, 2026
A
aidanmurphy
It's a 2005 merc 115. When I pulled the bearing carrier out the prop shaft along with the clutch dog / reverse gear / etc pulled out...
Apr 23, 2026
8
83bluefin
1983 Blue Fin 16’ Resto
May not look like it but left turn signal/brake, 3/4” marker in front of the tire, and marker up near the winch stand are wire in. Ran...
Apr 23, 2026
legalfee
Need help finding tachometer
Wiring is illustrated on the PDF I attached. Gray wire to Send. Purple wire (switched 12 volts) to IGN. And Black wire to GND.
Apr 23, 2026
Alpha One Gen 2 Shaft Seal Choice
Note at Mercruiserparts list the double lip seal is used on serial numbers 0M400412 and higher...
Apr 23, 2026
flashback
Boat transport
20 years ago I had a 27ft sailboat hauled from buford ga to chattanooga and it cost 5 bucks a mile on their trailer.
Apr 23, 2026
Fuel Sending unit
Yes, north American standard is 240-33
Apr 23, 2026
C
Crosbyman
2003 Johnson 150 throttle
https://www.bing.com/videos/riverview/relatedvideo?q=utube++oiling+shifter+cables&&mid=44EAD4B4E12E9FDF785844EAD4B4E12E9FDF7858&churl=htt...
Apr 23, 2026
Boat transport
Fuel is cheaper than maintenance costs.... boat transport will probably be $3/mile, so at 800 miles, about $2500
Apr 23, 2026
Grub54891
reacted to
redneck joe's post
in the thread
Random
with
Like
But what about sexy green chicks???
Apr 23, 2026
Grub54891
reacted to
redneck joe's post
in the thread
Random
with
Like
Only minus 3? Tis but a flesh wound....
Apr 23, 2026
Grub54891
Random
Well, as I say: it’s always awkward the first time……
Apr 23, 2026
D
DeepCMark58A
Boat transport
You can't own a boat and worry about fuel cost>:ROFLMAO:
Apr 23, 2026
