A
airshot
replied to the thread
1983 Blue Fin 16’ Resto
This boat is a 1983, some 45 years old. The wood in the transom was never sealed at the factory, so.....if you created a good plywood...
Apr 23, 2026
R
Mercury 5 HP 4-stroke won't start
Report the valve clearance that you found.----If motor does not pop with fuel in the cylinder you have no spark or spark at the wrong...
Apr 23, 2026
C
Crabeye
1982 starcraft v220 mariner v5 potential rebuild
UPDATE!!!! I Have boat floor of,stripped of foam,ready to rebuild and just acquired 21 ft Duckworth turnkey..Have decided to sell...So...
Apr 23, 2026
R
2003 Johnson 150 throttle
Remove cables at the motor.----Operate linkages and see how they move.----Perhaps lubricate them.-----Picture of your controls...
Apr 23, 2026
M
Mark R.
Alpha One Gen 2 Shaft Seal Choice
Hey, thank you for the reply to my question. The seal I'm referring to is actually #5 in this assembly drawing...
Apr 23, 2026
S
solitude
Yep. Just confused by it not feeling good for me but the mechanic said it's working fine. And hasn't changed since I got the boat
Apr 23, 2026
C
Crabeye
WELL...I am ready to get said rivets set and now have just acquired a 21ft. Duckworth welded boat!! So beleive i am going to put my 1983...
Apr 23, 2026
R
robinfla52
All good
Apr 23, 2026
R
Cracked bearing carrier, run or replace?
Maybe reverse gear was not lined up with pinion.----Slow rotation of crankshaft while slowly tightening might be the way to go.
Apr 23, 2026
A
aidanmurphy
It's a 2005 merc 115. When I pulled the bearing carrier out the prop shaft along with the clutch dog / reverse gear / etc pulled out...
Apr 23, 2026
8
83bluefin
May not look like it but left turn signal/brake, 3/4” marker in front of the tire, and marker up near the winch stand are wire in. Ran...
Apr 23, 2026
legalfee
Need help finding tachometer
Wiring is illustrated on the PDF I attached. Gray wire to Send. Purple wire (switched 12 volts) to IGN. And Black wire to GND.
Apr 23, 2026
Note at Mercruiserparts list the double lip seal is used on serial numbers 0M400412 and higher...
Apr 23, 2026
flashback
Boat transport
20 years ago I had a 27ft sailboat hauled from buford ga to chattanooga and it cost 5 bucks a mile on their trailer.
Apr 23, 2026
Fuel Sending unit
Yes, north American standard is 240-33
Apr 23, 2026
