P
Pmt133
reacted to
dingbat's post
in the thread
New old boat checklist.
with
Like
The 800 and 1,000 gph pump have different size outputs. Plan on swapping out the hose and thru hull fitting if going larger
Apr 25, 2026
matt167
replied to the thread
I think what I have is 3/4” which is what is on the boat.
Apr 25, 2026
dingbat
Apr 25, 2026
matt167
I forgot to update this after first outing. Obviously knowing it’s an ‘89 it had a high probability of breaking down first time out...
Apr 25, 2026
C
carlos515
Ebbtide 2008
Thanks for the replies. I ended up passing on the boat.
Apr 25, 2026
Starter stays running.
Ayuh,.... Welcome Aboard,...... The only way to answer yer question, is by Testing the start circuit,..... Get yerself a test...
Apr 25, 2026
W
whydoihateboats
posted the thread
in
OMC I/O & Inboard Engines & Outdrives
1991 Chris Craft. Just out of storage. We went to start it and the engine fired right up but the starter stayed running, turned the...
Apr 25, 2026
redneck joe
reacted to
tphoyt's post
in the thread
There almost here
with
Like
There getting so close I can taste em.
Apr 25, 2026
redneck joe
18ft Boat Launch with RWD Suburban
I had to use 4x4 once, on a very shallow ramp when I had my dually, which are not good for traction. Very slimy ramp but because so...
Apr 25, 2026
redneck joe
Hot water heater
In a tank version, once it is hot it becomes a hot water heater keeping the hot water hot.
Apr 25, 2026
S
SunnyD1964
posted the thread
ID needed please.
in
Arkansas Traveler
I have what I believe to be a traveler, not sure what model Year is 1964, 17ft fiberglass im trying to restore it. And wanting new trim...
Apr 24, 2026
nola mike
Alpha One Gen 2 Shaft Seal Choice
No rolling torque on his drive, it's a basic torque setting.
Apr 24, 2026
A
airshot
reacted to
Bugzilla46310's post
in the thread
1983 Blue Fin 16’ Resto
with
Like
I’ve used the True Mods 3/4” lights. Very inexpensive and bright. When I get around to repainting the boat trailer I will convert to...
Apr 24, 2026
P
Pmt133
My grandfather used a VW beetle with his 17' wellcraft. I think you'll be alright. (Highly sketchy as I was told.)
Apr 24, 2026
LaqueRatt
Boat Cover Repair?
Good to know thanks.
Apr 24, 2026
