  • Bondo
    Bondo replied to the thread Starter stays running..
    Ayuh,..... at the switch, the yellow/ red wire should be powered Only when the key is in the Start position,.....
  • P
    Tested a 2011 Tahoe Q5i with 4.3L mercruiser and 14 x 23” prop. All seemed to be good except WOT resulted in ~3300 RPM & 39 MPH. Two...
  • W
    whydoihateboats replied to the thread Starter stays running..
  • W
    I have a test light and multi meter, just no idea where to start.
  • J
    Jeff J reacted to Bondo's post in the thread Starter stays running. with Like Like.
    Ayuh,.... Welcome Aboard,...... The only way to answer yer question, is by Testing the start circuit,..... Get yerself a test...
  • J
    jlh3rd reacted to KD4UPL's post in the thread Hot water heater with Like Like.
    Are you asking about electric or gas? If gas it's probably a good idea unless your water has a lot of mineral content. If electric you...
  • FLATHEAD
    FLATHEAD replied to the thread There almost here.
    Good luck on them. 😎They are in the Delaware River for a couple weeks now. A friend has been after them in bucks county, no big ones in...
  • Scott Danforth
    Scott Danforth reacted to Bondo's post in the thread Starter stays running. with Like Like.
  • alldodge
    alldodge replied to the thread ID needed please..
    Welcome The boat was licensed at one time, do you have the title or bill of sale? Contact the state which licensed it and they should be...
  • P
    Pmt133 reacted to dingbat's post in the thread New old boat checklist. with Like Like.
    The 800 and 1,000 gph pump have different size outputs. Plan on swapping out the hose and thru hull fitting if going larger
  • matt167
    matt167 replied to the thread New old boat checklist..
    I think what I have is 3/4” which is what is on the boat.
  • dingbat
    dingbat replied to the thread New old boat checklist..
  • matt167
    I forgot to update this after first outing. Obviously knowing it’s an ‘89 it had a high probability of breaking down first time out...
  • C
    carlos515 replied to the thread Ebbtide 2008.
    Thanks for the replies. I ended up passing on the boat.
  • Bondo
