Lou C
replied to the thread
454 mag mpi chuggles/stalls
2 four-barrel carb manifolds 2 Edelbrock 4bbl carbs 2 simple low pressure electric fuel pumps from Michigan Motorz that would be my...
Sunday at 8:17 AM
which order to do maintenance
Easier to drain the drive before removing, unless you have a stand to place the drive on keeping it up right If you have a greasable...
Sunday at 8:10 AM
C
carlos515
Question on cap removal
Ok, the supports in my picture are not enough? Would I have to build a cradle for the hull?
Sunday at 8:03 AM
Lou C
Glastron GXL 235 anti siphon valve location?
It will always be right where the fuel hose from the pump hooks up to the fuel pick up tube. Excuse the dirty fuel tank my boat is 38...
Sunday at 7:48 AM
reacted to
vroom ZOOM's post
in the thread
with
Like
Sorry should have been more clear, the new FPR solved the issue of the fuel pressure slowly dropping after the engine turned off, it...
Sunday at 7:36 AM
vroom ZOOM
Sunday at 7:35 AM
P
Pmt133
I/O (Sterndrive) Conversion to Outboards
Graphite works well as well. Allegedly coarse threads are less prone to it.
Sunday at 7:23 AM
reacted to
racerone's post
in the thread
with
Like
Support the hull so it does not distort while structural elements are removed.
Sunday at 7:21 AM
T
Tdunne96
reacted to
racerone's post
in the thread
Johnson 25 Prop size
with
Like
Need to determine issue with top cylinder.----Fuel pump diaphragm ruptured??----Reed valve issue?
Sunday at 7:18 AM
T
TXGlastron
Exhaust manifold discovery?
Airshot, I’ll take my lumps as deserved. The winterizing was my fault. I had my boat on the lift, and hadn’t been able to get back to...
Sunday at 7:15 AM
M
MikeSchinlaub
reacted to
racerone's post
in the thread
with
Like
Sunday at 7:14 AM
T
TXGlastron
Mercruiser 5.7L and 5.0L, help me identify a part
Thanks Fun Times. I’ll grab a couple of pictures in just a bit. I do still have the 5.0L info because they forgot and gave me the old...
Sunday at 7:12 AM
Grub54891
reacted to
redneck joe's post
in the thread
Random
with
Like
I've got a very complicated relationship with religion, this however is one of my favorites https://www.facebook.com/share/v/1G2a8sPduX/
Sunday at 7:04 AM
Grub54891
reacted to
redneck joe's post
in the thread
Random
with
Like
https://www.facebook.com/share/v/1CtFExyqnR/
Sunday at 7:02 AM
P
Popeye303
reacted to
dingbat's post
in the thread
Too Much Prop Issue?
with
Like
Something really wrong. You’re pushing 1,200 - 1,400 rpm short of where you need to be. Too much to be a prop Engine problems, water...
Sunday at 6:48 AM
