  • C
    carlos515 replied to the thread Question on cap removal.
    I mentioned before in my original posting of the Sunray, that I will need to replace the hull, stiffeners? Would making the stringers...
  • A
    airshot replied to the thread Exhaust manifold discovery?.
    Most of us boat owners have had to learn some hard lessons over the years, your not alone !
  • C
    That would work also.
  • M
    MikeSchinlaub replied to the thread Question on cap removal.
    That would be much easier. I've also used a sawzall. Tape a stir stick to a long blade, and put some adhesive backed dand paper on the...
  • I
    Ilya83 reacted to alldodge's post in the thread 454 mag mpi chuggles/stalls with Like Like.
    It doesn't run, then it does, they it doesn't Bad connection somewhere, and that as you know will be hard to find
  • vroom ZOOM
    vroom ZOOM replied to the thread 454 mag mpi chuggles/stalls.
    Yeah, I thought about that a lot of times. Unfortunately I need to sell the boat, so for a boat getting listed for a bunch of money...
  • C
    The only reason I need to take the cap off is to get the top of the transom ground for new glass. Perhaps I should get a long neck...
  • nola mike
    nola mike reacted to Lou C's post in the thread 454 mag mpi chuggles/stalls with Like Like.
    2 four-barrel carb manifolds 2 Edelbrock 4bbl carbs 2 simple low pressure electric fuel pumps from Michigan Motorz that would be my...
  • nola mike
    Yeah not sure what I was thinking of there... Doesn't require that on a gen 1, or some gen 1 input shaft seals, so not sure whether I...
  • Lou C
    Lou C replied to the thread 454 mag mpi chuggles/stalls.
  • alldodge
    alldodge replied to the thread which order to do maintenance.
    Easier to drain the drive before removing, unless you have a stand to place the drive on keeping it up right If you have a greasable...
  • C
    Ok, the supports in my picture are not enough? Would I have to build a cradle for the hull?
  • Lou C
    It will always be right where the fuel hose from the pump hooks up to the fuel pick up tube. Excuse the dirty fuel tank my boat is 38...
  • alldodge
    alldodge reacted to vroom ZOOM's post in the thread 454 mag mpi chuggles/stalls with Like Like.
    Sorry should have been more clear, the new FPR solved the issue of the fuel pressure slowly dropping after the engine turned off, it...
  • vroom ZOOM
