M
muc
replied to the thread
Oil 4 stroke Mercury 115hp
Since 2014 10w-30 has been recommended for the 115. Make sure to use the Synthetic Blend You can use the 25w-40 if your operating in a...
Sunday at 3:42 PM
J
JasonB
83 7.5hp, smoke from cowl
No loose bolts, the video makes it sound strange. I pulled the power head. The old gasket had some form of yellow sealant on it. Would...
Sunday at 3:40 PM
which order to do maintenance
The gimbal is part of the transom assembly not the outdrive. The outdrive drive shaft goes in thru the gimbal and into the motor...
Sunday at 3:39 PM
Merc 250 Verado Fuel increase
Assuming 3, first click Acc and if switches return to this position VV powers down but Plotters stay ON. Second click 2 beeps and VV...
Sunday at 3:31 PM
9
995jim
isnt the u joint in the outdrive called the gimble? I assume you have to pull it apart to grease. 1990 vintage
Sunday at 3:31 PM
M
Mc Tool
Mounting bracket for j200
⅜" aint a lot ,can you post a pic of the bracket ....so we can see if there is enough " meat" there to slightly elongating the holes...
Sunday at 2:45 PM
M
Mc Tool
reacted to
Crosbyman's post
in the thread
with
Like
somebody Knows. me I would seal existing holes with silicone or epoxy and drill new holes where they are needed.
Sunday at 2:37 PM
C
Crosbyman
Sunday at 2:32 PM
M
Mc Tool
Just thought I'd share a nice photo.
Yeah but they are not unmanageable and they get you into some premo fishing areas , lot of peeps wont use them so you usually have it...
Sunday at 2:30 PM
M
muc
Thanks for the info, it helps. Do you have 3 or 4 position key switches? A 4 position will have an accessory position if you turn it...
Sunday at 2:13 PM
M
Mc Tool
reacted to
redneck joe's post
in the thread
Random
with
Like
I've got a very complicated relationship with religion, this however is one of my favorites https://www.facebook.com/share/v/1G2a8sPduX/
Sunday at 1:41 PM
redneck joe
2026 NFL/CFB News and Nonsense
Loving this.... https://www.facebook.com/share/r/15nuD4JD6M5/
Sunday at 1:30 PM
flashback
reacted to
tpenfield's post
in the thread
I/O (Sterndrive) Conversion to Outboards
with
Like
@flashback , here is a diagram that I used to show the need for spacers to some folks on another forum ( some people . . . :rolleyes...
Sunday at 1:28 PM
A
airshot
Too Much Prop Issue?
This glass boat is far heavier than my 22' aluminum boat. My boat runs a 19" pitch and the motor runs perfect. Still sounds like there...
Sunday at 1:27 PM
J
jasonburba74
Mercruiser 4.3L wire harness
That's what I was thinking. Thanks for the information.
Sunday at 1:27 PM
