M
muc
replied to the thread
Merc 250 Verado Fuel increase
Take a look at 8M0156798 install instructions page pages 40-41 Some builders will use a buss bar for the negatives and that's fine. But...
Sunday at 4:31 PM
Lou C
Oil 4 stroke Mercury 115hp
I have used the expensive Mercury/Quicksilver oil and gotten excellent oil analysis results on my old 4.3 that still has the original 38...
Sunday at 4:30 PM
M
Mc Tool
Exhaust manifold discovery?
Yeah , Ive always been at a loss as to why anyone wouldnt run proper coolant thru a heat exchanger . I wouldnt put salt water in my car...
Sunday at 4:30 PM
T
tphoyt
Mounting bracket for j200
I’m with Crosbyman. I’d fill the old holes with an epoxy filler and start fresh to help keep any water out of a sloppy hole.
Sunday at 4:25 PM
M
Mc Tool
reacted to
Lou C's post
in the thread
with
Like
Low maintenance boat = outboard Raw water cooled I/O = unforgiving of even 1 mistake Closed cooled I/O is better but there'd still be...
Sunday at 4:23 PM
Lou C
Sunday at 4:14 PM
which order to do maintenance
Agree the drive is removed to grease U joints
Sunday at 3:50 PM
reacted to
995jim's post
in the thread
with
Like
yes, I was confused with terminology sorry my bad as I was referring to the drive shaft u joint. thanks
Sunday at 3:49 PM
9
995jim
Sunday at 3:44 PM
M
muc
Since 2014 10w-30 has been recommended for the 115. Make sure to use the Synthetic Blend You can use the 25w-40 if your operating in a...
Sunday at 3:42 PM
J
JasonB
83 7.5hp, smoke from cowl
No loose bolts, the video makes it sound strange. I pulled the power head. The old gasket had some form of yellow sealant on it. Would...
Sunday at 3:40 PM
The gimbal is part of the transom assembly not the outdrive. The outdrive drive shaft goes in thru the gimbal and into the motor...
Sunday at 3:39 PM
Assuming 3, first click Acc and if switches return to this position VV powers down but Plotters stay ON. Second click 2 beeps and VV...
Sunday at 3:31 PM
9
995jim
isnt the u joint in the outdrive called the gimble? I assume you have to pull it apart to grease. 1990 vintage
Sunday at 3:31 PM
M
Mc Tool
⅜" aint a lot ,can you post a pic of the bracket ....so we can see if there is enough " meat" there to slightly elongating the holes...
Sunday at 2:45 PM
