A
airshot
replied to the thread
pontoon engine pod replacement
Go to a Fab shop and have one made, or have yours modified to meet your specs. Finding one already made will be scarce, very scarce.
Sunday at 6:57 PM
A
airshot
reacted to
racerone's post
in the thread
with
Like
Easy fix with some wedges or shimming.
Sunday at 6:54 PM
A
airshot
Exhaust manifold discovery?
Having an outboard that self drains helps a lot in salt water. Glad I am not close enough to salt water to have those issues.
Sunday at 6:50 PM
D
DeepCMark58A
2026 NFL/CFB News and Nonsense
That is a chocolate for ya. My wife says no more dogs after the two we have but I had a legendary chocolate, thing is living on a lake...
Sunday at 6:45 PM
1966starcraft18ft
i did go out and measure the engine pod and there is a 7 inch negative angle to my engine pod over a 16". i also used the angle finder...
Sunday at 6:44 PM
O
ostrichegg
2005 Mercruiser 5.0L MPI (bravo 3) suddenly started overheating
Thanks. I should have noted, I thought maybe seaweed or something (or maybe a bag) got my drive. But, I don't see anything on the...
Sunday at 6:34 PM
G
gmarshall43
posted the thread
1939 Evinrude gas tank
in
Johnson & Evinrude Outboards
Hello Is the gas tank for a 1939 1.8hp Evinrude the same size as the 1938 2.8hp Evinrude handiwin? Just wondering if they are...
Sunday at 6:10 PM
R
Sunday at 5:56 PM
S
sbs_59
posted the thread
24v Battery Charging Options
in
Electrical, Electronics, Audio and Trolling Motors
Currently have a 24v trolling motor that uses 2 12v batteries with a plug in on board charger. The boat will be docked in a location...
Sunday at 5:50 PM
J
jlh3rd
I've owned my used pontoon since 2017. I've researched all aspects and items including getting new pontoons. I've never seen any type of...
Sunday at 5:37 PM
Lou C
Oil 4 stroke Mercury 115hp
IIRC when Merc came out with their 25/40 mineral oil they also said that if it wasn't available you could use straight 30 in cooler...
Sunday at 5:27 PM
J
jlh3rd
fwiw. The 2 years in the brackish upper chesapeake with my new in 2021 Merc 115 has not hurt it. Just changed the impeller and checked...
Sunday at 5:24 PM
Might have found a plastic bag floating around and it wrapped it self around the drive. Check your impeller because if may have been burned
Sunday at 5:20 PM
Merc 250 Verado Fuel increase
Working from 2B529482 manual Don't know where this is and it's never done this, can you advise? Will do Don't have this one, can you...
Sunday at 5:15 PM
1966starcraft18ft
posted the thread
in
Pontoons
hey all. so i replaced the 1988 force `125 hp on my 1998 MonArch sunspa 260 with a 1999 Mercury 125 hp outboard. I noticed with both...
Sunday at 5:14 PM
