Scott06
replied to the thread
Mercruiser 4.3L wire harness
willing to bet that goes to mercathode or something on the transom housing - what does it connect to inside the boat? As mentioned...
Monday at 11:47 AM
L
Lpgc
reacted to
airshot's post
in the thread
Exhaust manifold discovery?
with
Like
If they drained one, they typically drain everything. Why would anyone not drain the manifolds while your down in there opening the...
Monday at 11:45 AM
Merc 250 Verado Fuel increase
Guessing this is LED's on the throttle handles, and if so I have not watched for them during start sequence The isolator (might also be...
Monday at 11:44 AM
D
DeepCMark58A
I always drain then add the antifreeze/water mix. A stitch in time saves 9
Monday at 11:42 AM
L
Lpgc
reacted to
Lou C's post
in the thread
with
Like
It seems unlikely because it's much easier to drain the manifolds on most V6s and V8s than the block drains. After my first experience...
Monday at 11:41 AM
L
Lpgc
reacted to
DeepCMark58A's post
in the thread
with
Like
And it takes less than 15 minutes to do correctly, and also why I alway mix antifreeze and add it till it comes out the exaust, cheap...
Monday at 11:40 AM
L
Lpgc
I agree if someone drains one they'll most likely drain everything. You, I and most here would drain everything but I'd bet there are...
Monday at 11:40 AM
M
muc
Monday at 11:30 AM
Thanks I'm still tracing but so far there is only one isolator and I don't know what it's powering as yet, might be taking the place of...
Monday at 11:30 AM
D
DeepCMark58A
Can't handle a screw and a rudder?
Monday at 11:15 AM
D
DeepCMark58A
reacted to
Lpgc's post
in the thread
with
Like
If you see cracked risers / manifolds due to freeze damage, isn't there a chance whoever 'winterised' it did at least drain the block...
Monday at 11:14 AM
D
DeepCMark58A
Monday at 11:14 AM
R
2002 200hpEvinrude 2 stroke
Do you have a local shop willing to work on it?
Monday at 11:13 AM
D
DeepCMark58A
reacted to
airshot's post
in the thread
with
Like
This is why I do my own work, way to many shops charging big bucks for poor service !
Monday at 11:13 AM
D
DeepCMark58A
reacted to
Scott Danforth's post
in the thread
with
Like
That is a classic example of thermal declination material breach due to volumetric expansion Your block is most likely cracked too If...
Monday at 11:13 AM
