R
replied to the thread
1983 Johnson 140 Horse J140TLCT No Spark.
Rectifier is not needed to make the spark.---The 12 volt battery is NOT involved in making the spark.-----The FAST spinning flywheel...
Monday at 3:46 PM
R
Oil 4 stroke Mercury 115hp
How much power does a car engine produce when cruising 50 MPH ( 80 KMH ) when cruising on a level road ?----Compare that to a 18' boat...
Monday at 3:37 PM
S
saltchuckmatt
83 7.5hp, smoke from cowl
Not factory...at least none that I've seen. Should be an easy fix. Any corrosion on the mating surface?
Monday at 3:06 PM
L
Lpgc
reacted to
tpenfield's post
in the thread
I/O (Sterndrive) Conversion to Outboards
with
Like
If it's not grinding, it's drilling . . . I went through several cobalt bits . . . amazing what a sharp drill can do . . . It reminds...
Monday at 2:26 PM
J
Jade Rose Papa
posted the thread
in
Johnson & Evinrude Outboards
I am a retired Jet Engine Mechanic but this Outboard stuff has me scratching my head. I have a 1983 Johnson Seahorse 140 with no spark...
Monday at 2:21 PM
Merc 250 Verado Fuel increase
When starting motors using start/stop the throttle handle LEDs were lit before during and after start, run and shut down
Monday at 2:15 PM
nola mike
reacted to
Kola16's post
in the thread
Does This Sound Right? Bravo Install
with
Like
Okay, I had to chase down a couple other issues I had come up first. My O2 sensor went bad, so I replaced that and it works now. My...
Monday at 2:13 PM
Accomplished Gen 2 Control test SB 2025-05R2 and no beeps Verified the pic in post 62 is a combiner ALT test SB 2021-21 Unknown if I...
Monday at 2:13 PM
M
Mc Tool
Mounting bracket for j200
Ok , your kinda stuck with the bottom holes as they go thru the transom and if they are not right for the new motor ( not the bracket )...
Monday at 2:12 PM
M
Mc Tool
I have never bought a new motor so Im not tied in by any warranty . I have had this argument/discussion many times . While I understand...
Monday at 1:57 PM
reacted to
Kola16's post
in the thread
with
Like
Monday at 1:52 PM
454 mag mpi chuggles/stalls
If all plugs are like that one looks like your rings need to seat Oil rings put in correctly
Monday at 1:51 PM
vroom ZOOM
Well, did some more testing. I scoped the TPS and it has a weird blip every now and then where the voltage drops to 0.16v, the rises to...
Monday at 1:40 PM
redneck joe
reacted to
aspeck's post
in the thread
2026 NFL/CFB News and Nonsense
with
Like
Is anyone really surprised? His temper tantrums and sulking made him a liability to any team that would have been interested in him.
Monday at 1:38 PM
redneck joe
1973 Starcraft SuperSport 16ft. restoration questions
Do what you can, when you can and the boat is secondary to the wife. We understand but i i hope typing it all out helps tou.
Monday at 1:35 PM
