O
ostrichegg
replied to the thread
2005 Mercruiser 5.0L MPI (bravo 3) suddenly started overheating
Yep, thanks! Answers: 1) Not sure how impeller looks, but it was replaced about 6 months ago, maybe 8 months ago. 2) This is raw water...
Monday at 4:36 PM
J
Jade Rose Papa
1983 Johnson 140 Horse J140TLCT No Spark.
Wow, I got a Trophy. I will Check the Battery, Starter Motor is working as advertised. Thank You
Monday at 4:35 PM
M
Mc Tool
Oil 4 stroke Mercury 115hp
Im thinking this has to be a rhetorical question (there are to many variables to give a concise answer ) ,but I do see where you coming...
Monday at 4:32 PM
C
Chuck4741444
Mounting bracket for j200
What do you think about milling the 2 top holes ovel? Would it weaking the brackets?
Monday at 4:14 PM
C
Chuck4741444
Monday at 4:00 PM
9
99yam40
I need some input on a 1991 Yamaha c115tlrp
if there is no spark ,you need to measure the voltages into and out of the CDI
Monday at 3:53 PM
R
Rectifier is not needed to make the spark.---The 12 volt battery is NOT involved in making the spark.-----The FAST spinning flywheel...
Monday at 3:46 PM
R
How much power does a car engine produce when cruising 50 MPH ( 80 KMH ) when cruising on a level road ?----Compare that to a 18' boat...
Monday at 3:37 PM
S
saltchuckmatt
83 7.5hp, smoke from cowl
Not factory...at least none that I've seen. Should be an easy fix. Any corrosion on the mating surface?
Monday at 3:06 PM
L
Lpgc
reacted to
tpenfield's post
in the thread
I/O (Sterndrive) Conversion to Outboards
with
Like
If it's not grinding, it's drilling . . . I went through several cobalt bits . . . amazing what a sharp drill can do . . . It reminds...
Monday at 2:26 PM
J
Jade Rose Papa
posted the thread
in
Johnson & Evinrude Outboards
I am a retired Jet Engine Mechanic but this Outboard stuff has me scratching my head. I have a 1983 Johnson Seahorse 140 with no spark...
Monday at 2:21 PM
Merc 250 Verado Fuel increase
When starting motors using start/stop the throttle handle LEDs were lit before during and after start, run and shut down
Monday at 2:15 PM
nola mike
reacted to
Kola16's post
in the thread
Does This Sound Right? Bravo Install
with
Like
Okay, I had to chase down a couple other issues I had come up first. My O2 sensor went bad, so I replaced that and it works now. My...
Monday at 2:13 PM
Accomplished Gen 2 Control test SB 2025-05R2 and no beeps Verified the pic in post 62 is a combiner ALT test SB 2021-21 Unknown if I...
Monday at 2:13 PM
M
Mc Tool
Ok , your kinda stuck with the bottom holes as they go thru the transom and if they are not right for the new motor ( not the bracket )...
Monday at 2:12 PM
