M
MikeSchinlaub
replied to the thread
Painting factory diamond pattern non-skid.
I haven't used this specific product, but the prep principals should be the same. It's hard to tell from the picture, but the areas...
Monday at 8:48 PM
Rranger
reacted to
ddrieck's post
in the thread
o. k. to put electric fuel pump on outboard?
with
Like
Re: o. k. to put electric fuel pump on outboard? I disagree to a point... As stated above, do not install an electric fuel pump in...
Monday at 8:04 PM
B
boscoe99
24v Battery Charging Options
What is the main motor? What does its alternator output? One advantage of lithium is how quickly it can be recharged.
Monday at 7:56 PM
S
saltchuckmatt
1983 Johnson 140 Horse J140TLCT No Spark.
It's a 2 stroke....find another outboard. She's done. Airplanes clime, then they level off and descend...outboards are going up hills...
Monday at 7:44 PM
S
saltchuckmatt
Mounting bracket for j200
I see the 3/16 thing now or I get the math, oval the holes...you will be fine. Top only, right? Should need to though. Everything...
Monday at 7:36 PM
S
saltchuckmatt
I have those brackets on my E-tec 115. I've done two of them. They should bolt right on...was your boat missed drilled? You said 3/8...
Monday at 7:31 PM
P
Pmt133
Oil 4 stroke Mercury 115hp
I'm in the "theres a spec and testing for that specs endorsement for a reason" camp. I've messed around and tested various oils in other...
Monday at 7:28 PM
rothfm
Thanks....gonna see what others put here. Then may take 1 small hatch as a test and use a wheel of some sort (that wont gouge the...
Monday at 7:18 PM
rothfm
reacted to
airshot's post
in the thread
with
Like
I painted some diamond plate years back, but the paint lifted in some areas. Then tried sand blasting the plate. Looked great and paint...
Monday at 7:16 PM
A
airshot
I will add this.....go to the Eway and get on, leave your car in first gear and go cruise at 70-75 mph all day. Lets see how long your...
Monday at 7:10 PM
A
aidanmurphy
Cracked bearing carrier, run or replace?
Tried again today with the new carrier and got the same issue.... 1/8th inch gap left. Tried turning the shaft while sliding it in. I do...
Monday at 6:59 PM
A
airshot
Monday at 6:57 PM
J
Jade Rose Papa
I have spark, Checked some connections and cleaned a couple that looked a little suspect, Put a full charge on the battery...
Monday at 6:21 PM
C
Chuck4741444
Thanks. Ill file them larger.
Monday at 6:12 PM
Kola16
2005 Mercruiser 5.0L MPI (bravo 3) suddenly started overheating
I am not sure on the transom flush port question. 170F for a normal operating temperature of a raw water cooled engine seems high to me...
Monday at 6:08 PM
